Wood Splitter
  • Wood Splitter
    Has anyone had any experience with a wood splitter? The logs I have are a little large and I find that smaller pieces work better. I bought a pedal type splitter from Amazon but it was terrible and I returned it.
    Re: Wood Splitter
    Oh I'm sure you will get a lot of comments on wood splitters!
    I will start - I have used several. When I have a lot of wood to split I rent a tow-behind beast that is powerful and fast. For a lot of wood, I find speed to be a bigger issue than the power - but you don't want one that is underpowered either.
    I own a manual splitter from Harbor Freight which s fine for splitting 1-2 firings of wood.
    If I only need a few smaller pieces it is easiest to use a wedge (it looks like a large chisel) and a hammer. If the wood is dry you can split plenty of pre-cut pieces remarkably quickly
      Re: Wood Splitter
      I have one of these. They really work well
      Amazon.com : Fiskars 7884 X27 Super Splitting Axe, 36-Inch : Patio, Lawn & Garden
      But I should note - I love spending an afternoon splitting firewood. I find it relaxing, and there's nothing as satisfying as seeing that stack of split wood when you're done.
      My build progress
      My WFO Journal on Facebook
        Re: Wood Splitter
        Hi, we have been using electric log splitters for years. We bought the first one from lowes. The splitter worked well until I loaned it to a friend and it came back with a bent rail. I was unable to get the replacement part from the manufacturer and lowes refunded my money. I will put a link to our current splitter at the end of the post. This splitter lets me work from my wheelchair. It stores easily and takes little space in the vertical position. Bruce
        http://www.amazon.com/Powerhouse-XM-...XX4K64TWVTH47N
        Link to my build here:
        http://www.fornobravo.com/forum/f6/3...lly-19181.html
        Selected pictures of the build.
        https://picasaweb.google.com/1168565...g&noredirect=1
        sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
          Re: Wood Splitter
          You don't want to mess around splitting wood - get one of these and make us ALL jealous https://www.youtube.com/watch?v=X0-1Rx1NNDY
            Re: Wood Splitter
            wow! I need one of those!!
              Re: Wood Splitter
              I thought this was pretty cool... for kindling
              https://www.youtube.com/watch?v=Ro2wMb7zJ60
              My build: http://www.fornobravo.com/forum/f8/4...way-19491.html
                Re: Wood Splitter
                G'day steellearning
                That's a pretty" cool tool " I would really like one of those. I'm pretty much a one armed axe man due to an old injury. That would produce the sticks id like ( with or without the dramatic music "
                  Re: Wood Splitter
                  I still use an old Maul. Works best on Red Oak.
                  Most of the wood in the pile for the wood stove but the oven will be well have plenty.
                    Re: Wood Splitter
                    We burn wood both in our WFO and to heat our home so we go thru a fair bit of wood each year. Three neighbors and I went together and purchased a much more expensive and better splitter than any of us could otherwise justify. Of course it is towable.
                    As we own it we can basically take as much time as we want splitting wood rather than being under a time constraint using a rental unit. Maintenance has been low as it has a quality Honda motor and one of us in our group has spare space in his garage so it is stored indoors.
                    If you have neighbors also burning wood this might be a worth considering.
                    Hope this helps,
                    Wiley
                      Re: Wood Splitter
                      It depends on how much wood you have to split. At most I've had a 1/2 cord to split at a time and hence I've found a mall to work fine as our spruce and birch is fairly easy to split except when you get into spruce with lots of limbs. For kindling I just use an axe.
                      If you're just splitting up larger pieces for the WFO I can't see going to the expense of a wood splitter. Also if you have a chainsaw you can cut up the occasional large piece. You can also use a chainsaw to cut an X in the end of the log to give the mall or wedge a starting place and it makes it much easier to split.
                        Re: Wood Splitter
                        In Australia our hardwoods are all eucalypts and most of it is quite hard to split, some extremely so. I find simply cutting the lengths shorter, say less than a foot, makes splitting far easier.
                          Re: Wood Splitter
                          Hello All
                          I may need to get a wood splitter. I have just scored a couple of loads of Oak. Some of it is about 30" diameter,
                          David
                            Re: Wood Splitter
                            David,
                            Good score on the wood!
                            I would suggest that the answer as to purchasing a splitter would be determined by asking is this a one time occurrence or something that will occur several times a year?
                            If it is a one time occurrence: I would rent.
                            If it is something that looks like it will happen once every year on a ongoing basis: then I would still rent.
                            Something ongoing (as in several times a year): then certainly I would purchase a splitter.
                            All that being said, having tools is cool and fun and so if you can afford a splitter and want one, then get one. (I knew a guy once who bought a riding lawn mower and he had a residential sized yard. He wanted the mower and could afford it so he bought it. No further justification needed).
                            Hope this helps,
                            Wiley
                              Re: Wood Splitter
                              Hello Wiley
                              Went back today to get the last two logs. Someone had got one of them before I got there so I only got one.
                              That one had the most knots, probable why they left it.
                              This type of log score is not common for me so buying a log splitter will probable not be something that I will do right now. Renting is a better option and I may put one of the logs on my Wood Mizer Sawmill as it looks like a nice white oak. The slabs off the log still burn great.
                              I find that red oak splits easier with a maul. White oak can be tough.
                              The maul gives you a good work out if your back will stand it.
                              David
