G'day All,
Do you have a reasonably large oven? How do you overcome the heat and reach required to get wood deep in your oven?
I have an oven with dome a little larger than 42 inch and entry is 475mm (19") and I struggle unless the fire is centre. I would appreciate any feedback on methods used to get the wood in such ovens.
I do have very initial thoughts as to a device, that if required and nothing better pops up I'll make. Rough drawing included. Initial thoughts as to how to accommodate variety of size timber was with the offset as indicated on the diagram. Thoughts now are to have a wider opening at one side and jagged edges to prevent side slip, as indicated on diagram, lower left. Handle position and angle will be important for easy release of the subject log.
Appreciate any thoughts.
Kind Regards
Greg
Kind Regards
Greg
