Proofing - raising questions????
  • nissanneill
    • Apr 2007
    • 1886
    #16
    Re: Proofing - raising questions????
    It really does pay to ask questions here!!!
    Proof positive. I took your advice and made up the dough on saturday night ata round 9-10 pm and left it to proof on the dining room table (a room rarely used and not heated), The picture shows the rewsults of the 2 spicy bun mix in the blue containers, a multigrain and German multigrain behing them and a double Russell Jeavons white bread recipe in the bowl behind those. I checked the temp on arising sunday am (well around 8.00 am and it was 15?C.Next time, I will proof them in the fridge as I feel that they over proofed, but they shaped up and cooked fine. The German multigrain was still a little dense and rather heavy but that could be the very nature of the beast.
    I was a little impatient with the first bake (visitors about to leave), and put them in at 750?F for 10 minutes. The buns got a little burnt on their bases but tasted great hot, straight out of the oven with butter dripping from them liberally. Hot rolls for lunch.... what could be better!
    I let the oven cool down, but left the coals in there and cooked the second batch with the help of a few water sprays to increase the humidity.
    I used tins and trays (wife's insistance) but did one piece directly on the floor.
    Have a few ideas to try next bake.
    Neill’s Pompeiii #1
    Neill’s kitchen underway
    • Dutchoven
      • Apr 2007
      • 931
      #17
      Good job! You got nice volume on them, colors are good. From here you will continue to fine tune all the factors involved. Juggling the balls of oven temperature, final proof and all will get easier as you go. I think you are well on the way.
      My best to you!
      Dutch
      • CanuckJim
        • Jan 2006
        • 1480
        #18
        Neill,
        You are definitely getting there. German breads by definition are heavier and more dense than other forumulas; it's a sort of national marque. This has to do not only with the weight of the whole grains used (rye, eg), but also the fact that rye and whole wheat do not have the gluten percentage of bread flour.
        The ideal temperature for retardation is 40 degrees Fahrenheit. That's fairly normal for North American fridges. At that temp, you can leave the dough for as long as 18 hours. At 50 degrees, it shouldn't retard for more than about 8 hours. These figures are for wild yeast/sourdough breads, but with proper commercial yeast amounts, they would still apply for other formulas.
        Personally, I would empty the oven of all coals and ash before baking, then bake directly on the brick with the oven door in place. (Except for pan breads, of course.) This, along with proper steam, will produce maximum spring/volume. The steam should be vented about halfway through the bake to allow the crust to develop.
        Your photographs of the bulk dough do suggest they are verging on over-fermented, so a drop in temp would help. If you're converting a commercial yeast/one-day bread to the retardation technique, try cutting the commercial yeast back by about half.
        Jim
        • nissanneill
          • Apr 2007
          • 1886
          #19
          Thanks for that guys,
          I value your input.
          Jim, I plan next time to reduce the yeast slightly and to proof in the fridge which runs at 4?C or 39?F. It is easier to do the night before rather than have to rush it all on the day.
          I will remove the coals *(didn't this time as I have yet to get a steel bin and plastic doesn't appreciate the heat) and sweep out the hearth as I normally do. I do want to try to get a slight (very slight) smokey tast to the bread as I did a couple of weeks ago. A real talking point and something different than merely baked in a WFO.
          I used a spray bottle to pump in humidity several times but the crusts were more than adequate for our liking.
          Had some of the left over buns last night and I got the consumate approval from the very fussy wife. She is slowly coming around and accepting not only the oven but my attempts at a late career start in cooking. All the kids and friends love it and want more. Re-assuring feedback!.
          Jim,
          not that I'm into difficult challenges, what is this 'wild yeast' that you professional refer to? Is it a culture that you grow for use in your baking? a bit like my mother used to keep for brewing ginger beer many many moons ago?
          I was using a live yeast but this last batch I used dry yeast which I now prefer, for obvious reasons. Tossed out the fresh yeast this morning as a result.
          Neill’s Pompeiii #1
          • CanuckJim
            • Jan 2006
            • 1480
            #20
            Neill,
            Call it a sourdough, a levain, a barm, wild yeast or what have you, they all refer to propogating a culture of the resident airbourne yeast in a particular area. The are about a zillion ways of going about beginning one of these, but there's really no mystery to it. Just create a receptive environment of water and flour, and the yeast and other good bugs will take up residence. It takes a while to do this, but once you've got it, you've got it. The flavour of wild yeast bread beats commercial yeast hollow.
            Jim
            • KiwiPete
              • Sep 2005
              • 108
              #21
              Or you can buy some from an outfit like Sourdoughs International: sourdough bread starter, sourdough bread recipes, bread machine recipes They sell a variety of wild yeasts and they come with some instructions etc.
              (No connection with them, other than being a satisfied customer).
              Peter
              Originally posted by CanuckJim
              Neill,
              Jim
              • CanuckJim
                • Jan 2006
                • 1480
                #22
                Peter,
                Sure, you can buy your initial starter, then build from there. It's important to point out, though, that unless you have a microbiology lab handy, there's no way to prevent the resident yeast in your area from invading the store bought culture and taking over eventually. The other guys simply will be outnumbered once the mix is exposed to your atmosphere. Buying it at first will definitely save you some time, though.
                Jim
                  #23
                  You know that white film on the skins of table grapes? Yeast. They similarly grow on wheat grains, so if you get some organic stone ground flour it's gonna have yeast in it already. There's a lot of talk about hundred year old yeast cultures, but yeasts are all around you. Give 'em something to eat, and a warm place to propagate, and they will go to work for you.
                  • james
                    Brick Oven Merchant
                    • Mar 2005
                    • 4648
                    #24
                    Plums. I made a tangy starter from some plums in an untended field on time. Definitely organic.
                    It seems as though tending your starter is where the real effort comes in. A good starter will go bad if you don't look after it. Worse than kids and pets.
                    Is that right?
                    • Unofornaio
                      • Jun 2007
                      • 323
                      #25
                      Hey James,
                      You are right very much like a child. Raising a starter (culture) is like having a newborn. You have to feed it every 4 hours or so, make sure its comfortable, check its temperature.
                      If I remember correctly during the process you need to pour some off every so often then once its going you need to maintain it. I had one that I kept going for about a year then lost it I made it out of the peals of oranges and I swear it had a orange nuance to it it might of just been psychological though. I was kind of anal about it though, using only water that I had soaked the peals in (we had several trees at the house)
                      Jim forgive me if I'm off a bit. I seem to have the process jumbled in my head.
                      There is the ferment stage creating the yeast well not creating it is there it just needs the right conditions to create spores. Then there is the process of building this yeast up to strength enough to raise the dough (thats the every 4 hr part hu? then its a matter of maintaining it. I'm gonna have to get the books out.
                      • CanuckJim
                        • Jan 2006
                        • 1480
                        #26
                        Uno,
                        Like I said, there are about a zillion ways of going about starting a culture, the main ones being using fruit and not. Some are incredibly elaborate and time consuming; unnecessarily so in my opinion. The easiest, most straightforward and successful method I've found is in Peter Reinhart's The Bread Baker's Apprentice, pps. 227-232. You start by making a seed culture. This takes four days, using a combination of dark rye and high gluten (strong) or bread flour. During this period, the culture is cut in half, then fed, then cut in half, etc. After four days, you move on to what he calls the Barm stage. Essentially, you're building up the seed culture with flour and water. This mixture won't achieve its full flavor for several weeks, over several feedings, because lactobacilli need time to establish themselves, too.
                        Once the barm is established, some should be used and the remainder doubled for next time. It's that simple; no four hour feedings, no excessive time spent.
                        The pic I'm posting in the Gallery is of a feeding, build, elaboration, call it what you will, of 8 ounces of barm, plus 16 ounces of bread flour and 16 ounces of water. I let it sit overnight at room temp, and you can see, I hope, the frothy bubbles on top, as well as the bubbles deep in the mixture. At this stage, it's ready to use. I've made more than I need, but the rest will go back into the fridge until next time. This overnight development is an adaptation of Hamelman's method in his book: Bread.
                        As I've said elsewhere, it's important to use the best high gluten or bread flour you can get, plus the best water you can find. Sourdoughs of this sort are sensitive to water quality and the presence of grain sugars in the wheat.
                        As feedings progress, you can manipulate the sourness by using proportions of whole wheat or whole rye to increase it or going with straight bread flour to reduce it.
                        Jim
                        • nissanneill
                          • Apr 2007
                          • 1886
                          #27
                          Thanks for that Jim,
                          I will see if I can get the book and 'try' the wild yeast propogation.
                          I am leaning a little towards the dry yeast receipe, (Yeh, yeh, the bland easy way out, I know), but I don't honestly feel that my taste buds are that sensitive (or caring for that matter especially at this stage in the oven offerings), to 'appreciate the delicate nature of the special flours, yeasts and especially the tastes given off through buring almond or fruit wood'. I seem to be very happy with the results of burning dry gum (Eucalyt) timbers and cannot tast the oils given off during the burning.
                          I haven't yet developed a taste difference for the fresh or dry yeasts, maybe a little down the track.
                          Neill’s Pompeiii #1
                          • Unofornaio
                            • Jun 2007
                            • 323
                            #28
                            There is NO equal to naturally leavened bread in my mind. Maybe we could put together a "starter" exchange or something? Lets see.... who has more "copious amounts of free time" ?? ...and the room goes silent..
                            Hey thanks again Jim
                            • CanuckJim
                              • Jan 2006
                              • 1480
                              #29
                              Uno,
                              I've dried my starter and shipped it to as far away as Arizona. It's chancy, but it can work.
                              Jim
                              • Dutchoven
                                • Apr 2007
                                • 931
                                #30
                                Jim
                                I couldn't really tell from the photo, is your levain softer or firmer? I usually work from the firmer, and less messy, mother "dough" as opposed to the softer versions. Just wanted to know what your preference was. I knew someone who spent a good bit of money on a starter from Egypt. He was very disappointed when after a few months his bread tasted nearly the same as loaves baked using one cultivated locally. Waste of money if you do it just for taste, convenience on the other hand is a better reason. My starter was developed using Reinhart's instructions from the BBA and I can say it was the least time consuming of any I or my wife tried. We did the fermented organic grapes and many other methods.
                                Best to everyone!
                                Dutch
