Re: Roasting a suckling pig
CoyoteVB
I used a fire blanket (the one you extinguish kitchen fires with) just to hold the heat in while I bring the temp in the oven up.
The last time I cook a suckling pig in the oven I did exactly what you suggested. I started with the temp high & then slow cooked. What I found is that the skin did not crackle as much as I would have liked. The meat was perfect both ways, it was just that final result of the skin that was different. In a month or so I will be doing a pork leg without the bone in much the same way. Will let you know the out come.
CoyoteVB
