Re: My Wood fired Redux
Make some damn pizza already.
For the last brick below the flue base, I beveled the last full brick in the arch to create a sort of ledge. This allows the filler brick to lay at a right angle, and tuck under the flue base to transfer some of the flue weight into the middle of the vent brick.
The ledge...
Filler brick. This isn't the one I used, but a piece for testing the fit and angle of the bevel.
This is the inside after the piece is mortared in.
The opening starts at 11" and opens to 16" in the final full brick. The filler is beveled to direct gas and smoke towards the flue opening, to the 8" flue. This creates sort of a smoke chamber and I've had great success with this in the other ovens. Not necessarily needed, but it works, and it's no extra trouble to do.
Framing layout starts tomorrow afternoon....I'm hoping to start framing Tuesday.3 Photos
Built the vent and flue base yesterday and that's the last of the brickwork. I incorporated a thermal break in this vent, the first one. The reasoning is sound, and vent walls are never tied into the oven arch anyway, so I thought, why not? I'm going to pack it with mineral wool and then a black stove gasket, tucked back a bit.
I opened the arch by a little over 2", creating a 1" reveal for the door (yet to be built) This arch is better than the oven opening, because my granite one is going to be clean, and I don't want the vent brick visually breaking the arch I carve in the stone.
1 Photo
You're welcome and thank you.Originally posted by UtahBeehiver View PostStonecutter,
Thanks for the pick, sure looks good for fake lick and stick. You definitely have an eye to make fake or real stone have that random look. Very nice. Type N mortar 2:1 are what components again? Also, can't pay the bills working on your WFO so you have to do what you need to do.
2 = SAND 1 = TYPE N masonry cement. You can also get an acrylic admix like Arcryl 60 (quickcrete admix at big box stores) and add a bit to your mix.
It does help to burn the mortar on the back of the 'stone' ( sorry I must do the quote!) before you butter it up....just like tile work.Last edited by stonecutter; 06-14-2013, 08:19 PM.
Stonecutter,
As for my oven, total stall mode now. Every weekend for the last six have been spent on a commercial project..going 7 days will kill any home project.
But it looks like I only need to be there Saturday, so maybe I will be able to put up some framing on Sunday.
Specifically for Utah Beehiver, this is the fake stone project I mentioned in your thread. Type N mortar mixed 2:1 over a portland based scratch coat and lath.
Even though I would never favor adhered veneer over natural stone, I must say it came out better than expected. I don't love the window trim, but those are 22.5* corners (which are mitered) and there was only around 6.5" between the window and the corner, so field pattern wouldn't work like it did below the trim...I wove the 'stone' to avoid a continuous joint.
HO & GC are happy, and I am keeping the wolves away....win - win.4 PhotosLast edited by stonecutter; 06-14-2013, 06:01 PM.
Thanks guys. Style wise, I was influenced by the Inca stonework in machu picchu, and some Japanese stone work I saw. The joints were kept to no more than 3/16".
Gudday
Wow.... That's one pretty piece of work!
I noticed in one shot a piece of stone work intruding on the arch.... Subtle but subdued ... Completely random...I'm not artistic ( my art teacher called my a scribler) ... But do appreciate the art and the finish of your craft !
DaveLast edited by cobblerdave; 05-19-2013, 02:28 AM.
I hear ya' Stonecutter,
That is some beautiful work, stone and hearth. I am still trying to get a finish with wet sand paper. I can actually see a little sheen in places on my work, but nothing like that. I just caught David's post and on his and your recomendations, I just might have to spring for the wet polisher and diamond pads
Installed...
The mix is a highly engineered sand only blend, with a little fiber too. There was also a polymer added, and this concrete is very hard when fully cured...over 6000 psi. I treat it like stone, meaning I profile the edges by hand rather than form them in the mould...because it creates sharper detailing. It also polishes up very nicely, I took this hearth all the way to 3000 grit, then buff, seal and wax. Anyway, this technique has broad applications, and can be used for sinks ( hey Gulf! ) and architectural pieces.3 Photos
No I don't mind at all. I had posted another concrete slab I did ( for a fireplace hearth ) on another thread but I can't remember where. I'll upload the pics to this thread and if you want those too, feel free.Originally posted by UtahBeehiver View PostStonecutter,
I added your formed concrete to a concrete counter link that I maintain if that is okay. It has a hot link in Lburou's FB treasure archives in the Newbie section.
Stonecutter,
Tons of rain the last week and a half. I have only managed to slurry the profiled edges on the watertable...nothing else really. I am hoping to be able to frame around the oven to dry it in and insulate it this weekend. If not..because there may be more rain, I'll at least start carving the outer arch, which will be a solid chunk of granite.
