Originally posted by Kurtloup
View Post
I am using melamine on my table top, and made the form from pvc trim board. I have used melamine for the forms in the past, but I'm finding that the trim holds up to multiple castings. Also, I only use hot glue to put them together...no screws anywhere on the form. The other material you have should be fine too. Clean the form well then apply release agent...I use wd-40 or armor-all, but any kind of lightweight oil is works.
I did vibrate the grey pieces you see in this thread, because they are cast with a flowable mixture. I use the standard 3:2:1 - 1/2 (h2o) but tweek it a bit. I also add an acrylic or polymer admix to the concrete as well. Bagged concrete mixes work well too. The others are a combination of hand pressed and a technique called Scagliola.
I can shoot you some links in a PM...let me dig some up, not sure about the rules on that here. In the meantime, check the forums for some info. There are a few folks in here that have done some superb concrete work...to name a few - Gulf, Utah Beehiver, neil2...many more.
To me this is more of a personal preference anyway, the end result would be the same..I doubt I would be any faster applying more mortar. But that's me...not saying it's wrong.
