Re: 82cm Corner Underway in Bulgaria
Gudday Paul
You should change your thinking about the mortar. Yes as your building it grabs each brick and holds it together. But the last brick goes in its role changes.
You have built yourself a dome. Gravity now becomes the thing that holds that dome together and makes it such a strong structure. The mortar become now somthing that seperates the bricks. The weight above bears down and its those Inside horizontal joints that are inportant to the strength of the structure. The mortar at the back and sides just position the brick and aren't really the load bearing bit.
By the way I use the Queensland Gudday. It's not as clipped as that from the Guday from down south and said a little more slowly, still one word ,but with 2 difined different 'D' sounds. Spell check hates it
Gudday Paul
