Re: Another Aussie Oven
My bricks came from the front fence of a 92 yr old house and are solid reds. I had to clean the mortar off them first and then I used an angle grinder 230cm and a small 115cm to do the finer work with a daimond disk. It was dusty work but worth the work for sure. You might be interested to know that it took me 8 months and 19 days, with about 400 hrs build time and at least 400 stubbies to complete the oven. If you are using FF mortar you will be OK it has performed very well for me and if you follow their curing method you will be cooking in no time with no cracks. Ask Leigh for the curing sheet they supply and stick to it.
