After renting a bigger saw. I made the arch fit a bit better
Russell. These cuts are made before putting the bricks into the arch?
i can cut the inside. The outside cut doesn’t make sense yet.
It seems to me that it would cut into the face of the bricks in the outside of the arch.
The cuts to rest the dome on are exceedingly challenging. And I wonder if those are better done by hand when the arch is together?
You are not alone, it is a difficult concept to mentally see but once the light bulb comes on the you go "Okay I See". Double check the length of the TDC, it does look a little short, left side of the brick in area should be the longest and most times extends past the front of the arch form. You can take measurements with a pencil on another full size brick and start the pointed double angle side right at the right edge of the new brick.to compare with the one you cut.
I always recommend a adjustable one, it is easier to build a non adjustable one (so many head this way) but in the long run it is better to spend the time up front and make the IT adjustable.
On another note, the reason IT gets in the way at TDC, remember the arch form is set at the radius at floor level, IE 21" I think, as you move up the pivot point off the floor starts to come into play, so now your radius starts to increase, say at this point some where around 21" plus 1" +-, then maxing out the top of dome. So you can play with the IT radius while you doing the tapered arch bricks. Also, remember the cuts on the bricks are not the same left to right of TDC, you need to cut each one separate base on the IT and the previous brick cut.
