Re: Oven Curing
On further inspection, no heat related cracking has been found. On Sunday I ran to Lowes and gathered steel studs and channel for the surround and I now have a steel box frame built 38? high around the dome. The next task is to apply ? inch thick Hardie Backer to the sides and back of the steel and block structure. This weekend, I'll line the interior of this outside wall with unfaced fiberglass insulation; this insulation will support the rockwool, RW, bats. I?ll use these RW bats directly against the dome. I have 3, 4 cuft, bags of vermiculite to fill in what holes I can't easily get RW or FG insulation into. I?ll be using all these materials to level out the insulation within the box. I'll be leaving some space around the insulation, next to the studs, to provide air movement and hopefully minimize humidity that would chew up the steel framing. Before I do a final pack on the insulation and dump the vermiculite I want to get the curing fires done and get the OMG fire behind me. This weekend I push forward with 500 and 600 degree burns and begin using wood rather than LP.
Sorry I don?t have any pictures, I?ll add some soon.
Chris
Chris
