Hi Everyone
In another post, I mentioned a Stainless Steel Oven that I was in the process of Building. Finally the oven was completed at my fabricator and boy was I excited. Then the excitement turned to disappointment yesterday when I fired it up for the first time. The oven is heating up quite well and you can feel the blazing inferno of the fire as can be seen in the video.
The problem I have is my Firebricks just can't get up to temperature. First I couldn't get it beyond 450f then I moved my fire around and managed to get it up to 575f with lots and lots of wood and a blazing inferno but that would drop quickly right after baking a pie - the temp would go right down to 380f. The outside of my oven gets hot to the touch such that placing your hand on the outer for more than 3 seconds could probably burn you - I tried to take a temperature reading but because the Stainless Steel has a mirror finish, the IR Thermometer bounced right of the mirror onto the closest object. I would estimate that the outside reaches around 250f.
Quick Summary of my Build
Oven is full stainless steel with an inner and outer dome (Ooni Pro Design but larger 70 X 70 Internal Area)
100mm Ceramic Fiber Blanket between the domes
75mm Ceramic Fiber Blanket at the Back of the oven
75mm Ceramic Fiber Blanket underneath the floor
The right ride of the oven has the firebrick enough to bake 2 X 30cm pizzas - exact dimension is 345mm X 690mm
Left side of the oven has a Stainless steel tray to hold the logs and acts as an ash tray as well
Inner dome height is just over 13"
Oven opening is 18" wide and 8.5" height
Firebrick is 25mm thick 35% alumina medium duty
Looking at the video ,https://youtu.be/T_ZGRyBOzE8 you will notice the flames from my fire doesn't lap around the dome and I know that might pose some issues - I'm not sure why this is the case and still trying to find out.
I'm desperately looking for some suggestions how to circumvent these problems I am experiencing?
Please help
Take Care
Om
Please help
Take Care
Om
