Stucco ideal mix
  • George_M
    • Oct 2014
    • 290
    Stucco ideal mix
    Hi,
    I need to make the final coat to my oven.
    Which is the best mix to make stucco?
    Thanks!
    • 5263
    Since you are in Greece and the oven is covered under the patio I would ask local trademen on this. I remember you are in the Athens area and the weather is not as severe there, find out the the locals do.
    • George_M
      • Oct 2014
      • 290
      Can i make my own mix?
      Maybe lime sand cement?
        • 5263
        Do a Google search and you will see dozen of formulas for DYIers. That is why I suggested you talk to local tradesmen using local materials.
        • fox
          • Mar 2017
          • 388
          4 fine sand, one part cement, half a part lime + plasticiser will make an nice easy to apply mix but it will not be water proof.
          i use that mix as a finale coat over a sharp sand 4 - 1 mix with adder plastic fibres.
          i use weather shield exterior house paint to water proof the top coat.
          • mongota
            • Jun 2011
            • 428
            I used a 3:1:1/2 mix plus water. First coat embeded the mix in the lath. Next day did a second coat. Roughly 3/8" to 1/2" thick per layer. I've been misting it today. Ill give it a few more days to cure prior to waterproofing with Thoroseal.
            Mongo
