Re: Stone Work Photos and Ideas
Chris
I am using mortar mix I buy at Lowes or Rona (like a Canadian Home Depot). I like the Lowes stuff because it comes in plastic bags.
However, you should know there are several kinds of mortar: Type S, Type N, and a few others. As I understand it, Type N is somewhat weaker (non-load bearing). It may have other merits, but I use Type S just in case what I am doing is 'load bearing'. Home Depot only carries Type N where I live for some reason.
You can also buy mortar cement (Type S or N or others, I guess) and mix it with sand yourself. I believe it is much cheaper to do it that way. I am going to use a good 30 66 pound bags so it adds up. I think mortar cement comes in Tye S and N as well. Anyway, I figure the mix is more convenient.
I am using a cement mixer (front load) and do 2 bags at a time. A mortar mixer (side load) would probably work better but you can't ask for everything.
I got inspired to try do it myself after seeing old fieldstone structures all over the place. I know some of these were made by professional, experienced masons, but I am sure many were made by farmers and their sons and they are still standing. So maybe I could come close to their efforts.
Great you found stones! Hopefully nobody will object to you liberating them.
Chris
