Has anyone ever used 3"Ceramic Fiber Board for insulation under your cooking floor Instead 2” Ceramic Fiber Board?
Ceramic Fiber Board
Tags: None
Re: Ceramic Fiber Board
I used three 1" layers of InsBlock 19. Others here have used ceramic based boards as well. 1", 2", 3", it's all the same basic idea. I believe insulation is fairly linear (2" is twice as good as 1", etc.).
does anyone know what i can put in between my ceramic board and firebricks? can i just use a normal refractory mortar?Comment
You mean the oven floor? I didn't put anything between them. The bricks went straight down on the board.
Ok thanks! i will make sure i cut them well so it fits together tight so they dont get gaps in between them.Comment
FBX insulation board
I bought some 2" FBX Insulation Board today from a refractory company. They told me to cut it with a butcher knife
QUESTION IS: How much weight can this material support? Should I use it for the floor bricks only and NOT the first chain?
A picture would help my understand here....
I apologize if it looks like I'm hyjacking your thread morrishuckeba
Lee B.
DFW area, Texas, USA
I try to learn from my mistakes, and from yours when you give me a heads up.Comment
Re: FBX insulation board
Whether you place the first chain on the floor or surrounding the floor, the ceramic board should be underneath the entire floor/dome wall assembly, regardless. The board has tremendous compressive strength.Comment
OK fxpose (George), let me run this by you and see if I really understand, OK?
The board can take the weight of the oven floor AND the dome, yes....?
(It seems very lightweight to do that). Do you put the dome directly on the board, or do you use a layer of sand and fireclay, or perhaps, some home brew?
Thanks for clarification
Yes, everything sits on the board, as you can see from this photo.OK fxpose (George), let me run this by you and see if I really understand, OK?
The firebricks sit directly on the board, and nothing in between (no fillers) as long as the board surface is nice and even.1 PhotoComment
Lee B.
Usually the board is flat enough to put the brick floor directly on the insulation board without any leveling medium. If one brick is a bit low you can supplement it with a bit of brick cutting slurry or fireclay.
Whether to build the dome on top of the floor bricks, or cut the floor bricks to fit inside the dome is entirely builders choice. I built my dome on the floor to avoid a few fussy cuts, and to distribute the weight a little more widely.
And yes, the board is strong enough to support your entire assembly. In my case I have two stories of heavy flue tiles piled on top of my entry, and there's no discernible settling. Remember: insulation boards are very crush resistant. They build entire buildings on top of a type of insulation board.Comment
That is what I was concerned about, thank you for giving me confidence.....That board feels light and delicate. I'm still gathering materials. Delayed also by freezing temperatures.snip....And yes, the board is strong enough to support your entire assembly. In my case I have two stories of heavy flue tiles piled on top of my entry, and there's no discernible settling. Remember: insulation boards are very crush resistant. They build entire buildings on top of a type of insulation board.
Lee B.
good morning lburou, i set a full brick soldier course on 2" and then put another 1" inside the circle before i laid the floor. i had a couple of floor bricks that i leveled with just a little bit of loose fire clay... and i did that after i was finished with the entire build.Comment
