Has anyone ever used 3"Ceramic Fiber Board for insulation under your cooking floor Instead 2” Ceramic Fiber Board?
Re: Ceramic Fiber Board
I used three 1" layers of InsBlock 19. Others here have used ceramic based boards as well. 1", 2", 3", it's all the same basic idea. I believe insulation is fairly linear (2" is twice as good as 1", etc.).
You mean the oven floor? I didn't put anything between them. The bricks went straight down on the board.
FBX insulation board
I bought some 2" FBX Insulation Board today from a refractory company. They told me to cut it with a butcher knife
QUESTION IS: How much weight can this material support? Should I use it for the floor bricks only and NOT the first chain?
A picture would help my understand here....
I apologize if it looks like I'm hyjacking your thread morrishuckebaLee B.
DFW area, Texas, USA
Re: FBX insulation board
Originally posted by Lburou View PostQUESTION IS: How much weight can this material support? Should I use it for the floor bricks only and NOT the first chain?
Originally posted by fxpose View PostWhether you place the first chain on the floor or surrounding the floor, the ceramic board should be underneath the entire floor/dome wall assembly, regardless. The board has tremendous compressive strength.
The board can take the weight of the oven floor AND the dome, yes....?
(It seems very lightweight to do that). Do you put the dome directly on the board, or do you use a layer of sand and fireclay, or perhaps, some home brew?
Thanks for clarificationLast edited by Lburou; 12-13-2010, 06:13 PM.Lee B.
Originally posted by Lburou View PostOK fxpose (George), let me run this by you and see if I really understand, OK?
The firebricks sit directly on the board, and nothing in between (no fillers) as long as the board surface is nice and even.
Originally posted by fxpose View PostYes, everything sits on the board, as you can see from this photo.
The firebricks sit directly on the board, and nothing in between (no fillers) as long as the board surface is nice and even.Lee B.
Usually the board is flat enough to put the brick floor directly on the insulation board without any leveling medium. If one brick is a bit low you can supplement it with a bit of brick cutting slurry or fireclay.
Whether to build the dome on top of the floor bricks, or cut the floor bricks to fit inside the dome is entirely builders choice. I built my dome on the floor to avoid a few fussy cuts, and to distribute the weight a little more widely.
And yes, the board is strong enough to support your entire assembly. In my case I have two stories of heavy flue tiles piled on top of my entry, and there's no discernible settling. Remember: insulation boards are very crush resistant. They build entire buildings on top of a type of insulation board.
Originally posted by dmun View Postsnip....And yes, the board is strong enough to support your entire assembly. In my case I have two stories of heavy flue tiles piled on top of my entry, and there's no discernible settling. Remember: insulation boards are very crush resistant. They build entire buildings on top of a type of insulation board.Lee B.
good morning lburou, i set a full brick soldier course on 2" and then put another 1" inside the circle before i laid the floor. i had a couple of floor bricks that i leveled with just a little bit of loose fire clay... and i did that after i was finished with the entire build.
