Required density of fiberboard insulation
  • brickie in oz
    • 3445
    #61
    Re: Required density of fiberboard insulation
    Ive had my oven over 800c.... you could smell it getting hot and melting the fibreglass rope that I used to have around the front entry, surprisingly it didnt melt the silastic that was holding it on, just crisped it.
    • GianniFocaccia
      • Jun 2009
      • 1645
      #62
      My plan is to copy others who place a light in the entryway away from the oven exhaust and point it in through the door. Easy to clean and replace the bulb.
      • WJW
        • Jan 2012
        • 388
        #63
        I haven't seen that on anyone's build. I'll have to do a search.
        Bill
          • 3884
          #64
          Can you post a link? This is a great idea! I haven't have even thought about this. I wonder if a permanent mounted light fashioned from flexible conduit or something similar would work. Something that could be moved out of the way when not in needed, maybe.
          • GianniFocaccia
            • Jun 2009
            • 1645
            #65
            Yes, this is the idea - but darn if I can remember whose thread it's in. It was at least 18 months ago (if I remember) when I saw it. I'll try to search some for it and hopefully come up with something.
            • Pompeii Nate
              • May 2011
              • 219
              #66
              I really love the idea of lights as well but I don't know if I am smart enough to put anything in without killing myself. Here are two different ideas for lights that I have seen and I like them both. The first one is from Christo and the second one is from bigred. I hope this helps.
              PhotoPlog - Finished Ovens
              Nate
              http://www.fornobravo.com/forum/f8/p...two-21068.html
              • Pompeii Nate
                • May 2011
                • 219
                #67
                To be more specific on Christo's light, see post #64 to see his pics of how he did his lights.
                Nate
                • brickie in oz
                  • 3445
                  #68
                  Nate
                  If you click on the link to the right that says #64 by the a single post will open then you can copy paste the URL into your post.
                  Like this, http://www.fornobravo.com/forum/44/r...tml#post127076
                  • Pompeii Nate
                    • May 2011
                    • 219
                    #69
                    Thanks for the tip Al! I am obviously still trying to learn to use this site to its full potential.
                      • 9215
                      #70
                      i think you might have been reading the F scale rather than C. If your oven was at 800C the bricks would be glowing orange.
                        • 9215
                        #71
                        Originally posted by WJW
                        Good point...I guess it needs to be someplace where the carbon will burn clean Is 1470 degrees F a high enough rating??
                        That's way more than you need.
                        • brickie in oz
                          • 3445
                          #72
                          Give it up Dave, the infra-red thermometer is set to C.
                          Who said the bricks werent glowing?
                            • 9215
                            #73
                            Wow, then that's hot! Way too hot to cook anything.
                            How long did it take to get that hot?
                            • brickie in oz
                              • 3445
                              #74
                              Correct.......
                              • V-wiz
                                • Oct 2012
                                • 737
                                #75
                                Sorry to bring this thread back to life, but i dont think this question was answered. What would be the minimum density required for the insulation boards. Would 15 LB density be enough to support the ovens? Thanks.
