Hello All,
Been lurking for a while but this is my first post. The amount of information here is amazing. Hats off to those responsible.
I'm in the process of trying to source local materials and have hung up on the insulation. I'd prefer to use fiber board over vermiculite for performance and compactness. That being said I'm finding the various fiberboard materials to be relatively pricey. Still leaning toward the fiberboard but I'm unclear as to what properties are required. I've come across two inch thick sheets rated to 2300F at densities ranging from 16 to 24 lbs per cubic foot. The prices vary significantly. Any thoughts on what is required? What does increased density get me? Resistance to compression?
Also, do I need board rated to 2300? Is 1800 degrees enough? I'm seeing boards rated to 1800 with a 19lb density which are 47"x39"x2" for $116. Same size and density with a temp rating of 2300 goes for $157. Is the extra temp rating worth the extra money?
Are there other sothern california sources out there anyone is aware of?
I've read that the FB store carries these supplies (and have seen the kits) but I don't see Fiberboard and blanket separately listed???
Bill
Bill
