Dome wall thickness question
  • olddude
    • Jul 2009
    • 61
    #16
    Re: Dome wall thickness question
    okay how about this one
    • olddude
      • Jul 2009
      • 61
      #17
      might help with the drawing lol
      • olddude
        • Jul 2009
        • 61
        #18
        if you build and opening like this the vent will work
          #19
          I'm afraid I don't understand this drawing. Is the vent in the oven chamber?
          • fxpose
            • Jul 2009
            • 942
            #20
            That's olddude's drawing. I don't think the square lines drawn inside the chamber are part of the vent.
            George
            My 34" WFO build
            • Neil2
              • Oct 2006
              • 1374
              #21
              "As far as the shallow entry goes, it will be rectangular with a flared side wall opening. "
              This is what I built and I am glad I did. It is a little trickier to make but you get much improved visibility and accessibility into the oven. Another benefit is that you can design a door with "wings" the same angle as the flare. This makes the door easier to place, makes a better seal and is freestanding without a base or struts.
              • olddude
                • Jul 2009
                • 61
                #22
                dmun this is what i was thinking that might work for his requirements
                • fxpose
                  • Jul 2009
                  • 942
                  #23
                  Thanks again, olddude.
                  I realize I don't have much latitude trying to build the largest oven I can fit within a 48" circle, especially placement and design of vent/entry. But I think got it figured out and your cad drawing pretty much nails it.
                  George
                  My 34" WFO build
                    #24
                    Yes, that makes more sense. It is possible to squeeze your oven opening into the insulation circle, but it makes it more difficult. I did pretty much the same thing, and ended building part of my flue support on the top of my dome.
                    It's really easier if you give yourself a little more room to work.
                    • olddude
                      • Jul 2009
                      • 61
                      #25
                      no problem i like trying to solve puzzles on cad need any dimention
                      worked out let me know i have that drawing saved.
                      • fxpose
                        • Jul 2009
                        • 942
                        #26
                        Those were exactly the two reasons for the flared opening.
                        Also, the fire in the chamber can be seen from a wider area.
                        George
                        My 34" WFO build
                        • fxpose
                          • Jul 2009
                          • 942
                          #27
                          I decided to go with the 3" wall thickness to maximize floor space. Starting from the 4th course up I can and might go with 4.5" bricks, as there will enough clearance from that course on upward.
                          I started erecting the dome yesterday:
                          George
                          My 34" WFO build
