Re: Casa90 Build
I think adding more insulation is always a good idea. So putting in your 3" of vermicrete under the ceramic board will just give you more "lasting power" on your oven's heat retention. Also having the final hearth height at the proper level for you will prove really valuable to your back. I'm just under 6' and my final hearth surface level is at 41". I can't tell you how nice it is to be able to work the oven standing instead of stooping! (I was fortunate to be able to work with an oven that was a bit too low for me before my build...so I really appreciate having a little more hearth height.)
Note that concrete continues to cure and harden for over a week after it is poured. Keeping it moist will actually increase its strength. Most contractors and masonry people I've talked to will keep a new pour moist and covered for at least one week before working on it. The downside of the vermicrete is that you need to give it some extra drying time before the insulation starts to work for you. That means you'll want to put in that insulation, let it cure, and then let it dry before you cover it totally with the rest of the build.
Hope that helps...
Hope that helps...
