Re: Casa90 Build
I would think 4 anchors per side to hold the track down would be fine. I would also use a 3/8 anchor, if you can get it long enough. go at least 2 inches deep, preferably deeper into the substrate.
here's a sample:
Wedge Anchor, Stl, Zinc, 1/2x7 L, PK10 - Wedge Anchors - Anchors - Fasteners : Grainger Industrial Supply
McMaster-Carr
If you can't get an anchor long enough, you can have a local place cut a threaded stud to length and set it into the hole with an epoxy or chemical anchoring adhesive.
Kind of a lot of work, but that's where' you are.
Pal
here's a sample:
McMaster-Carr
Pal
