Starting new 36" build
    • 5263
    #226
    Re: Starting new 36" build
    Hey DJ,
    I did not mean to put up on the spot. It is your build. But if you are interested, Cheng goes over accents on some of his YouTube videos. It is at least worth looking at. Even one or two color stones/crystals/fossils or accent could add bang to you hearth.
    • Amac
      • Nov 2011
      • 358
      #227
      Even one or two color stones/crystals/fossils..
      funny you should mention "fossil" Russel. I tamped in a small limestone fossil at the back of the oven - just to see how it would turn out after grinding.
      I never saw it again
      Amac
      Link to my WFO build
      • deejayoh
        • Jul 2010
        • 1893
        #228
        Insert part A
        Into slot B
        Probably should have used solids, but that was a sh!tload of cutting! I hope this works.
        • deejayoh
          • Jul 2010
          • 1893
          #229
          It fit! I am pretty happy with the results. I am amazed how much mortar one uses with regular bricks! About 100 pounds just to do that. Course, I had a coule of restarts...
          • Les
            • Sep 2005
            • 2945
            #230
            You don't want to use solids for this type of brick work - cores are stronger. Looks great!
            • dvm
              • Mar 2012
              • 242
              #231
              [ATTACH]31764[/ATTACH]
              Wow! An excellent result!
              dvm
              sigpic
                • 3885
                #232
                Hey DJ,
                ........if you are interested, Cheng goes over accents on some of his YouTube videos. It is at least worth looking at. Even one or two color stones/crystals/fossils or accent could add bang to you hearth.
                Let me echo Russell on this. "It is your build". This is one of those moments where your own creativity comes in to play. With the "up side down method" the sky is the limit.
                I am planning to use "cross section" sea shells and some "home made fossils" (if I can figure that one out) .
                Cheng, Buddy Rhodes, and a host of others out there have run the gamut on ideas. It is up to us to figure out what will accent our ovens without going "over board".
                However, with all that is going on with the complexity of a pompeii, I don't think that a plain concrete gray counter would take away from the final product: a WFO
                Just preaching to myself .
                PS, Great job! on the arch. I wouldn't call that a "faux arch". That is the real deal .
                  • 5263
                  #233
                  wow, nice brick arch. I am pouring counters tomorrow....wish me luck!
                  • deejayoh
                    • Jul 2010
                    • 1893
                    #234
                    Drystack stone veneer started going in today. Lots of cutting/tweaking - but I am pleased with the way it is turning out. Looks like I am going to have a bit of scrubbing the brick with Muriatic acid ahead of me though
                    • irelande5
                      • Feb 2012
                      • 133
                      #235
                      Looks great
                      http://www.fornobravo.com/forum/f8/p...s-i-18098.html
                        • 5263
                        #236
                        Very nice stone work.
                        • deejayoh
                          • Jul 2010
                          • 1893
                          #237
                          Thanks Russell and Irelande
                          I got a bit more of the stone laid yesterday, but spent a whole lotta time fitting the cabinet door. It's coming out better than I had hoped.
                          Off to HF this morning to pick up some supplies. I am taking the week off to finish up as much as I can before the weather goes south here. Expect to see lots of progress updates.
                          • GianniFocaccia
                            • Jun 2009
                            • 1645
                            #238
                            Beautiful, Dennis! Is there a name to the ledgestone you're installing? I really like the look.
                            • deejayoh
                              • Jul 2010
                              • 1893
                              #239
                              I am not 100% sure because I got it as a leftover from a friend's backyard kitchen install - but I think it is "Realstone"
                              It's pretty easy to work with
                              • deejayoh
                                • Jul 2010
                                • 1893
                                #240
                                Phew!! Lots of work done this week. I didn't post any updates because the progress was slow. Stone work and finish brick work takes forever.
                                I got most of the veneer on, and my decorative arch is now in place. I also mounted all the stainless storage doors/drawers in the kitchen area.
                                I had hoped to get my counters poured tomorrow, but it is looking like that will be a sunday activity instead. I lost a day to digging out the bamboo that had grown under a retaining wall in into my yard. It grew thru 4 feet of dirt! I dug a 5 foot deep hole, picked out all the rhizome I could find, and poured in some herbicide for good measure (I don't have anything growing that deep...) Capped the place where it got into my yard with 8 inches of concrete. Hopefully that will do the trick! Running bamboo is not something you want in your yard around here. It grows all too well.
                                Tomorrow I will get my forms all corner caulked, the reinforcement in place, the concrete on site, and the pigment weighed in prep for an early sunday pour.
                                Wish me luck
