Rather than continuing to start new threads on various topics, I'm going to consolidate here.
I'm saying that this snowy day today is officially the start of my build because I finally went to the local masonry center and they told me that yes, they do supply firebricks.
Only problem, is that this brick pictured is 8 1/4 inches. This is an expensive suburb, and they are charging 1.70 for these low duty bricks. Expensive yes.
The web site does say that they make the 9 x 4/5 x 2/5/. Here's hoping that the masonry yard will order them for me.
What is the general thinking these days as far as number of 9 inch bricks needed for a 36 inch dome?
(See some of my foundation chat here: https://www.fornobravo.com/forum/f6/...azy-19090.html)
Here is a picture of the bricks that they keep in stock. Also, see a spec sheet I downloaded from the supplier's web site. Good up to 2000 degrees. That should do it.
This manufacturer has a web site section called "Pizza oven resources" and they have a link to fornobravo, so I assume others have used their bricks.
The other picture is of the pallet warning. Don't you love it?
Also, a mockup of my stand. The stick is the approximate size of the dome when finished.
Same yard sells heatstop mortar for $66 a bag. I forgot to ask how big the bags were.
Regards, ronwass
Regards, ronwass
