I have decided to do a corner build oven under cover in my barn area.
I am a little restricted to size particulary now as I have laid my foundation slab (which is happily curing as I write) is 140 cm x 140cm (thats 55"x55" for those amongst us who are still in the old days of feet and inches and living too far for the romans to have ventured).
I was hoping to get a 91cm (36"internal oven. if not I shall make it 81cm(32")
I have curved the front of the foundation slab where my feet will stand at the entrance to the oven.
I was hoping that the blocks would be 40lx20hx20w (cm)which would fit exactly on the peripherals of my slab.(thats a big word for me)
Now I have just found out today that the blocks available in Bulgaria to enable me to build my hearth support are 40l x20h x15w wide which causes me a mathamatical problem Can anyone work out how to build my 4 course high support. With Diagonal frontage on hearth/entrance.
Also, Also, theres more, I have looked at all the corner builds and I cant see one example of how to breach the gap between the two front sides. Maybe I saw photos of one when it was completed, BUT HOW DID YOU DO IT!!
I will try to be more clear. On a normal slab you build the walls square or oblong and have access to all 4 sides, and put angle iron at the front to bridge the gap above the wood hole or whatever you may use the space under the hearth for.
On my intended corner oven,I will be trying to bridge this gap, with angle iron at a diagonal angle and somehow the blocks will have to be cut to suit that angle, but not being blessed with such skills of inteligence, I cant fathom out how this can be done.
Has any corner builder experienced this problem, is the gap not bridged in this normal fashion, will I have to go back to the drawing board? Will I be forever pizzaless?
Living in Bulgaria poses its many problems sourcing materials for the job is one, then of course theres the language barrier which doesnt help my plight, I may have to order some material from the Uk. I was offered asbestos when I enquired about insulation I havent been able to find Vermiculite but I think Ive found Perlite.
Its a challenge, but with the best help found anywhere on a website I will one day be in Pizzadom
Many Thanks in advance of all assistance.
YK
PLEASE READ POST 19. 40x20x20 BLOCKS ARE AVAILABLE IN BULGARIA
YK
