Re: 36" build in Tallahassee - AKA Bruce's Folly
Soak a cedar plank (generally 1/4" thick) for several hours then put it on a half-sheet pan.
Bring the oven into the 400F-450F range and keep a small fire going in the back or on one side with a hardwood of your choice...I like apple wood. Remember that the hearth has to be at temp as well because you are heating up the board and generating cedar infused steam to cook the fish from below.
Cover the plank with a layer of green onions and/or dill. Lay a filet of salmon, skin side down on the greenery. Put another layer of onions/dill on top of the salmon (thicker layer over the thinner portions of the filet to help even out the bake time) and slide into the oven. (Sorry, but I didn't note the weight of the salmon filet, however it was intended as dinner for four adults + good leftovers and was about 1"-1 1/2" thick in the middle). Damp down the door enough to keep the fire going but enough to allow some extra heat build-up. Our filet was done in 25-30 minutes, but you want to check it a couple of times possibly turning the sheet pan to manage the cooking...
When it came out of the oven, we let it rest for 10 minutes and then I removed the top greens. Last, I drizzled the filet with the citrus balsamic cream before cutting it into the serving pieces. I checked, but apparently my hunger overtook my photographer and I don't have any pictures...
