36" build in Tallahassee - AKA Bruce's Folly
  • deejayoh
    • Jul 2010
    • 1893
    #451
    Re: 36" build in Tallahassee - AKA Bruce's Folly
    Thanks! Looks good. I haven't tried with fig slices like that before. I will have to fire one up this weekend.
    • Bec1208
      • Nov 2012
      • 416
      #452
      Heavy rains today. Finally gave in and bought a pop-up canopy. It was on sale for $45.
      Link to my build here:
      http://www.fornobravo.com/forum/f6/3...lly-19181.html
      Selected pictures of the build.
      https://picasaweb.google.com/1168565...g&noredirect=1
      sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
      • stonecutter
        • Jun 2007
        • 2003
        #453
        Money well spent, Bruce.
        Old World Stone & Garden
        John Ruskin
          • 2848
          #454
          Gudday
          I agree ..... Will be perfect cover over a fold up table for your outdoor kitchen
          • Bec1208
            • Nov 2012
            • 416
            #455
            Gudday
            The canopy has come in handy with recent rains and as Dave points out should be useful after the oven is waterproofed.
            Have been working on chimney and finished today. Looking forward to trying it out though will have to move canopy to do so. How much clearance is needed?
            Will try to finish rounding dome and maybe work on bricking in the landing. We cooked the past few days with residual heat from Wenensday's fire. Did a pot of baked beans, a pasta casserole, a few baked potatoes, and used the oven to dry out some firewood. Temp right now is 212 F.
            • SableSprings
              Moderator
              • May 2009
              • 1310
              #456
              I wouldn't leave the canopy anywhere near the oven while firing. The nylon/plastic/canvas will burn and/or melt--guaranteed. When you watch the smoke coming out of the chimney during a firing you get a sense of how much heat is coming up that flue. As you noted during the "tarp incident", it doesn't take much to damage/melt any of those tarp & canopy materials. Also if/when the wind shifts, that hot stream of air will go laterally a lot farther than you think!
              I had a nylon canopy over my build, but always moved it well off to the side during firing. Even at that I got several small holes in the material from sparks coming out of the stack...and that was with a spark arrestor cap in place. You might find that by moving the canopy away from the pad (sideways or to the back you can get it out of the chimney exhaust stream adequately and have it reasonably available when you're done and can slide it back. (I even wondered at one point if it would be worth it to put casters in plastic pipe and put them on the canopy legs for rolling the canopy around.)
              No doubt the canopy is fabulous to keep the dome & front arch dry -- UNTIL you are firing the oven, then it's got to be moved away from the heat/smoke stream. Hate to have you find out how flammable it really is...
              Roseburg, Oregon
                • 2848
                #457
                Gudday Bruce
                All coming together real nice! Noticed the doors finished too and looking very tidy with it metal handles. That chimneys a stunner as well. So a period of dry wheather and the stucco is done. Can't wait for the recipes
                • Bec1208
                  • Nov 2012
                  • 416
                  #458
                  Pretty much what I thought. Wheels would sure make moving it easier. I hope to be able to fire up tomorrow. Thanks for your advice. I am curious to find out how hot the adapter plate will get. Bruce
                  • Bec1208
                    • Nov 2012
                    • 416
                    #459
                    Gudday Bruce
                    Thanks, it does seem to be coming together. If the weather cooperates I'm going to try and fire it back up and make a few pizzas. Probably keep it simple while I learn to work the oven. I'm not sure how much of the dome I can render in one session. Can the dome be stuccoed in sections if needed?
                    I took the door to the metal fab place I had ordered the angle iron from to ask advice. They offered to finish it for $50.00. It looks good but there a lot of direct contact of the door with the metal pan so door quickly heats up. Otherwise door works well and even without a gasket gets a good seal on the entry. Bruce
                    • stonecutter
                      • Jun 2007
                      • 2003
                      #460
                      You really shouldnt stucco in sections because that creates weak points and the layer will crack...think of it like a control joint in concrete flatwork. If its easier do several thin coats.
                      John Ruskin
                      • Bec1208
                        • Nov 2012
                        • 416
                        #461
                        Thanks, will be sure I'm rested before starting a layer. Made a small fire to test chimney, seems to be drawing fairly well. Thanks again for your help with the outer arch. Otherwise I would likely still be trying to work it out.
                        • Bec1208
                          • Nov 2012
                          • 416
                          #462
                          Tonight is the night to try high temp pies. I have five 300 gm dough balls prepared and the oven is fired up and ready to go. Wish me luck.
                            • 2848
                            #463
                            Gudday
                            Don't need to wish you luck, with all your hard work you have made your own luck it seems. I think you have done well in curing your oven in the wet conditions you have had. It's rained here as well, not a week had gone by since Feb without rain. Ovens dry inside but the outer brickwork is damp. And you can't seal it till its dry off course. I attach a photo it's starting to grown moss so you see what I mean.
                            • Bec1208
                              • Nov 2012
                              • 416
                              #464
                              Gudday
                              [ATTACH]37611[/ATTACH]
                              First ones out of oven.
                              • stonecutter
                                • Jun 2007
                                • 2003
                                #465
                                Looks good Bruce. Glad to be of help, that's what it's all about.
                                John Ruskin
