Originally posted by mnl
View Post
I would have to agree with Dave that the build doesn't have to be crazy complicated.
When I ventured into building my own WFO I was going to build a barrel vault for the same reasons as you. I had never laid a brick and I worried that the round dome "Pompeii oven" would be a impossible task for me. I kept thinking, how do you make a dome with square blocks that wont collapse. After studying and reading a lot online and on the FB forum I came to the conclusion that the round oven was a better fit for me because my main focus was pizza and not baking bread. Also, after reading the plans on this site the Dome build began to make way more sense and became less scary.
I used the standard method described in the Forno Bravo plans and used mostly the full bricks cut in half for the majority of my dome. Once I got about about 6 or 7 rings of the dome completed I realized that I now had gained the skills to step it up a notch and cut a bevel and taper in each brick to tighten up the gaps, but it is not necessary.
I really want to stress not to settle on the barrel/tunnel build because of lack of skill. I believe that just about anyone with determination and some patients can build the Dome. I did and I've never laid a brick prior to this project.
If I can be of any help let me know.
