temporary dry-stacked WFO - square design
  • #16
    Re: temporary dry-stacked WFO - square design
    Originally posted by TylerDavis View Post
    well I'd like to have the door in place during heat-up, which would be over 300 C. I plan to leave a hole and damper through the door to adjust airflow. Do I need to use refractory cement instead of Portland cement to make my perlcrete?
    Gudday
    You don't need an insulated door. An insulated door is to retain heat after the flames, not during firing. What you need is a blast door. It a simple door of metal , it doesn't require insulation as it reflects heat back into the oven. It doesn't need to be insulated and seal the oven mouth as it must be able to let smoke out and air in.
    • #17
      Gudday
      You don't need an insulated door. An insulated door is to retain heat after the flames, not during firing. What you need is a blast door. It a simple door of metal........
      Ahhh, but why not make insulated door anyway....it will do the job of two types of doors, rather than a single purpose blast door. Having two doors doesn't seem practical, but that's just my opinion.
      Old World Stone & Garden
      John Ruskin
      • #18
        Gudday
        Stone cutter ,Good point!
        I'm looking at his reason for TylerDavis needing having a door during firing anyway.
        TylerDavis...The entrance height is the same as the roof height, any heat escape long before it can be stored in the brick. The entrance height to oven interior roof height should be in a perfect world 63 per cent . And this in not just a forno thing its been around since these "black ovens" were built thousands of years ago. On the point of the ceiling of your oven as well, it might pay to put some thicker brick on top. Heat goes up and this is were you need some mass to store that heat in.TylerDavis you ovens dry stacked so you might want to use some angle iron for example to lower your entrance height down some.
        You'll find then the oven will "breath" efficiently. The flue gas will be burnt on the ceiling of you oven and you will have little visible smoke. As the flue gases escape the lowered entrance fresh air will be drawn in low to make the fire burn. The fire being contained in space were the heat is reflected back on the fire , the wood will be burn more efficiently than an open fire.
        • #19
          here are some updated photos of the current configuration
          cooking floor is effectively 18" deep by 23" wide, plus a little bit in front. But there is basically no entryway as I ran out of depth in my available space.
          Ceiling is 10.5" high. The 2" angle iron forms the only pseudo-entryway/arch. It definitely smokes a bit when the fire is getting going (as you can see from the charred brick faces), but once the logs are actively burning, it actually cleared quite a bit. I think I will lower the angle iron one course which will give me 7.5" entry height. 0.71 ratio instead of the perfect 0.63 ratio, but we ain't going for perfection here!
          The flue is a piece of HVAC duct, 9"x4" opening transitioning to 3" diameter outlet. Haven't done the math but seems like less than 0.15 of entry area. Considering rearranging so the flue in directly behind the entryway, rather than of to the left side.
          • #20
            Gudday
            That flue is sounding like it will be placed inside the oven. If that's the case you will be back to square one with the heat retention. Instead of the heat going out the door it will be going up the flu and the only thing you'll save is your eyebrows. These ovens have the flu outside the door for a reason, let your oven breath naturally like it wants to.
            On your hearth insulation it doesn't cover the whole of your structure. In further mods it might pay you with your heat retention to extend this.
