Re: Started my Build in Georgia
Except as previously explained, the insulation will help even out the temperature difference.
It will certainly reduce the rate at which the moisture is removed. Castable refractory manufacturers recommend that when eliminating moisture, if steam is visible then you are going at it too hard and to back the heat off. Presumably the same would apply for the mortar in an oven constructed of brick.
Like I said before, you can do it quickly and risk damage, but you can never do it too slowly.
I've certainly built defects in things , but I'm sure I've never been guilty of defection.
Originally posted by Laurentius
View Post
