Work of Love and Passion... Miami FL
  • DavidApp
    • Sep 2012
    • 348
    #61
    Re: Work of Love and Passion... Miami FL
    Hello
    You may consider some supports under the center of the form. It looks like it is a wide span.
    2 x 4 flat with 2 x 4 supports front middle and back should be enough, with wedges.
    Better too much support.
    Good luck with the pour. Have some cold ones ready for when it is done.
    David
    • gugahulk
      • May 2015
      • 195
      #62
      Originally posted by DavidApp
      Hello
      David
      Thanks David, I actually have them, see pictures below, this is what you mean? These are pictures looking from the floor up to the top on side, middle and other side. Thanks for your advice on everything. About the Cold ones, you bet! I actually have 2 cases for me and my friends ready to celebrate!
      Best Regards...
      Gugahulk!
      My Build...
      http://www.fornobravo.com/forum/f6/w...-fl-21793.html
      BUILD IT AND THEY WILL COME
      Food will always be the best way to spend time with family & friends, and that is all that really matters.
      STOP THINKING ABOUT IT AND DO IT!
        Those (I'm guessing 24" to 30"" spans on either side of your brick stand will bow under the weight of wet concrete.
        • mrchipster
          • Apr 2010
          • 1502
          #64
          I think if you screw 2x4 pieces from above thru the ply and have the 2x4 pieces below at the locations in photo you will be good to go.
          Sorry about the bad markup, I hope you see what I was going for.
          Chip
          • gugahulk
            • May 2015
            • 195
            #65
            I actually stood on top of the form yesterday and jumped on it. I weight 215lbs and all ok. So I am hopping it will survive the concrete murder pour!
            Best Regards...
            Gugahulk!
            My Build...
            • gugahulk
              • May 2015
              • 195
              #66
              Chip, actually that looks alot larger than it is on the live. I guess the light shinning tru makes it look like a huge gap. But your idea is a good, one. I have no more 2x4 and I would have to remove it all do to this. I don't think I will be able to so it. and I am hoping it will survive the pour. That thing is solid.
              Best Regards...
              Gugahulk!
              My Build...
                Sorry to alarm! I thought you were asking for advice. Good luck with the pour.
                • gugahulk
                  • May 2015
                  • 195
                  #68
                  Its all good buddy, thanks for the input. I appriciate it and if I had more 2x4 i would put it. But as you know $$$ is always an issue.
                  Best Regards...
                  Gugahulk!
                  My Build...
                  • gugahulk
                    • May 2015
                    • 195
                    #69
                    Guys I got a big problem! Need advice, I have not choice but to put the concrete on the rain today! Any advice, I can not postpone it! It must be done. Any help will be great.
                    Best Regards...
                    Gugahulk!
                    My Build...
                      Get a fairly good sized tarp. String something similar to a close line over the middle of your pour. The tarp in place over the hearth (like a pup tent) will give your pour some protection while your placing the concrete.
                      I hope this helps
                      • gugahulk
                        • May 2015
                        • 195
                        #71
                        Job done. So happy it worked all out. Thanks for all the support. No rain thank God!
                        Best Regards...
                        Gugahulk!
                        My Build...
                        • mrchipster
                          • Apr 2010
                          • 1502
                          #72
                          Nicely done, now cover it up to let it cure, and sit back for a week or so and contemplate, brick cutting, mortaring, and pizza.
                          Chip
                          • gugahulk
                            • May 2015
                            • 195
                            #73
                            Thanks Chip, Man I have to wait a week? What would be the minimum time? Believe it or not I was thinking about taking the forms out tonight, I thought 24hrs is plenty. But I will follow your advices. My previous projects had support on the floor that said there so the only worries was the sides and 24hrs was plenty for them to stay put. But this is my first time doing one with zero support and it will be "footing" on the sides. So not sure what to expect. Advices would be great.
                            Best Regards...
                            Gugahulk!
                            My Build...
                            • mrchipster
                              • Apr 2010
                              • 1502
                              #74
                              ,Do not pull your forms tonight!!!
                              For things to do in the next week before the forms come off read this post and other posts by "Brickie in oz"
                              One of the best barrel ovens out there and fantastic looking stone work. His design does not include a reveal for the door, he uses a flue damper, this is the only thing I would change is the door design. But he has his reasons for the way he built it and it seems to work well.
                              Advice, recommendations and discussions on finding local building materialsanywhere in the world.
                              Chip
                              • gugahulk
                                • May 2015
                                • 195
                                #75
                                http://www.fornobravo.com/forum/f44/...two-15241.html
                                Thanks Chip, I will for sure!
                                Best Regards...
                                Gugahulk!
                                My Build...
