FB Brand Insulation
This is a sticky topic.
  • thebadger
    • Jun 2007
    • 383
    #16
    Re: FB Brand Insulation
    James,
    I called to order some FB board (wanted to install on top of my vermiculite layer) and the girls said your out - is it really going to be 6 weeks before you get any in???
    I'm hoping to start the actuall oven in a few weeks.
    Dick
    • james
      Brick Oven Merchant
      • Mar 2005
      • 4648
      #17
      We are using SuperIsol to fill in, and matching the FB Board price. This should work out fine. Send me a PM with your contact info, and we give you a call.
      We blew through a big order of FB Board and Blanket, and we're waiting on the new container. Ah, supply chain.
      Stand by.
      • RCLake
        • Jul 2007
        • 433
        #18
        Stand by.
        I'm glad business is booming, I got my first order yesterday.
        RCLake
        "It's time to go Vertical"
        Oven Thread
        • Bayaba
          • Mar 2008
          • 5
          #19
          Could someone provide the specs for the FB Board?
          Also, is any progress being made on a TC kit?
          Thanks,
          Tom
          • builder brad
            • Apr 2008
            • 69
            #20
            Anyone know where I can get the ceramic insulating blanket in the UK?
            • Puy de Dome
              • Feb 2008
              • 179
              #21
              Google Yorkshire Refractories.
              PdD
              • Leados
                • Jul 2008
                • 3
                #22
                Hi
                I am in the process of getting all my materials up together to build a outdoor pizza oven.
                Can anyone help me with these questions.
                I am going build the pizza oven on steel frame with wheels (possibly angle iron),
                what would be the best and lightest material under the oven floor? and where would i purchase these items in Adelaide?
                I am going to build a domed clay oven, any tips and suggestions would be good.
                Leados
                • nissanneill
                  • Apr 2007
                  • 1886
                  #23
                  Hi Leados, and welcome aboard.
                  where abouts are you in Adelaide?
                  I ask as there are a few of us fellow FB forum members here.
                  To answer your supplier question, contact:
                  Thermal Ceramics Australia Pty Ltd
                  10-14 Toogood Avenue
                  Beverley Park 5009
                  South Australia
                  Australia
                  Phone: 61 8 8243 5300
                  Fax: 61 8 8243 0571
                  You will get onto a very efficient lady who has her finger on the pulse. I forget her name at present but will remeber it as soon as I send this reply to you.
                  Not bad on the eye either!
                  Neill’s Pompeiii #1
                  Neill’s kitchen underway
                  • mannextdoor
                    • Mar 2008
                    • 172
                    #24
                    I am using FB Board on my 42" build. How important is it to keep it dry though out the build? Even if you cover it and get a good rain, some water could run under and get to the board.
                    • james
                      Brick Oven Merchant
                      • Mar 2005
                      • 4648
                      #25
                      You should keep it dry. It's OK getting it wet when you are putting it on wet concrete, or putting mortar on top of it -- it dries and stays strong -- but you can't let it stay wet, or it will break down.
                      If you tarp it well, you should be fine.
                      • mannextdoor
                        • Mar 2008
                        • 172
                        #26
                        Thanks James. I want to do it right the first time.
                        • mfiore
                          • Oct 2007
                          • 919
                          #27
                          Is there any benefit to putting a coating of mortar on the outside edge of the board once it's up, to "seal" the edge at all?
                          Mike - Saginaw, MI
                          Picasa Web Album
                          My oven build thread
                          • tmcgree
                            • Oct 2008
                            • 1
                            #28
                            Hi,
                            I'm new to all this and am hoping to build my own oven sometime. Can anyone tell me which is preferrable for isulation - vermiculite, or fiberglass (or both) -- also is vermiculite essentially the same as perlite?
                            Thanks,
                            -Tom
                            • antonio cefalo
                              • Aug 2008
                              • 34
                              #29
                              Hello James,
                              Love the Fire board as a floor insulation in lieu of vermiculite. would it be ok to use 4" of the Fire board? my concern is that the stats indicate a 10% shrinkage, so that means a 2" board would shrink by 1/4". is this ok with the heavy oven on it? also, should sand or anything be put on the fireboard before you set the firebricks? thanks!
                              • james
                                Brick Oven Merchant
                                • Mar 2005
                                • 4648
                                #30
                                Ciao Antonio,
                                FB Board is definitely rigid enough to handle the weight of the Pompeii or FB precast oven -- a really large number have been installed that way. You can either set your bricks on sand, or on a bed of sand and fireclay (mix it with water and set it with a notched trowel). You tap your bricks to level with a rubber mallet either way.
                                2" will do it, though you can add a second layer if you would like.
                                Here is the FB Board pdf brochure.
                                Good luck!
