Re: Well i quess im building an oven!
Mortar mix ..... just add water
Mortar mix is sand and portland cement.....Refractory mortar mix is a specialized mix of sand and other ingredients....
...but if it comes as a mix, I think it's pre-prepared and you're good to go.
Jump in if anyone disagrees.
Ill post some pics in a bit, ive got three courses done and tommorrow i will figure out and assemble the door arch. I have come to see that the fire brick i got from work is probably medium duty brick, when i cut it open the density was far different than the brick i bought. Because they are tapered to begin with i thought i would use them on the last few courses. I hope they will be alright for oven use!
