Opening of WFO measurements?
  • Travelinman
    • Sep 2020
    • 40
    Hey Builders!
    I have not found actual measurements of the arch opening and angled actual opening.
    I am guessing the the inner arch is 18.5" and the outer arch is 21.5"-22.5" based on looking at photos. This would create a wider opening for cooking but still have the narrow opening for heat.
    is there a post or info on these measurements?
    Thanks to all.
    • 5262
    I suggest you download the free eplans from our host Forno Bravo, This info is in the plans and is based on the size and type of oven.
    • Travelinman
      • Sep 2020
      • 40
      UtahBeaver:
      I just was able to download the plans! Thanks!
      The plans are as good as the forum and site, in general.
      Thanks, again.
        • 5262
        The plans are a good baseline but somewhat dated and there have been many improvements developed by the members. It will give you a good start for design and layout and the members can fill in the gaps/
        • Travelinman
          • Sep 2020
          • 40
          I just read through the Pompeii Plans download, twice. I am glad the most of the early platform I accomplished correctly. thanks to advice here.
          I still have the same question, though.
          At the door opening there are flairs on some projects. It looks like a flair for access. Maybe 21" flaring out to 24-25" over a distance of 12" deep.
          Any idea if there are drawings of the flared entrance to use? I am concerned about the brickwork with the flared entrance and the angles.
          Thanks, all.
          • P3 Stoaker
            • Oct 2019
            • 135
            G'day Travelinman,
            I'm not 100% but I think the flare you refer to is in the "length" of the vent or opening? If this is correct the flare as far as I know is to allow for a door to be fitted against a reveal so as to keep the heat in. I've just completed my entry and I didn't do a flare, I have a reveal around 30mm which will allow a door to be installed.
            Regards
            Greg
            Adelaide, Australia.
            • Travelinman
              • Sep 2020
              • 40
              Thanks, Greg!
