My turn...finally - Forno Bravo Forum: The Wood-Fired Oven Community
My turn...finally
  • Re: My turn...finally
    John,
    Sorry about the delay getting back to you..I would need to measure it to be accurate but I believe it is about 14". I am not sure any thought actually went into that measurement. I made sure I had clearance on the backside for framing, If I had to do it over I would have moved it forward about 4" to give me some extra room in the back...My insulation is pretty tight up to the framing
    Peter
    Member WFO-AMB=WW
      Thanks for the info on the landing Peter, that will be a big help for my final design. You mention your insulation clearance is tight. How thick do you have your insulation? I don't want to skimp on insulation for sure!
      Thanks Again!
      John
        John,
        Along the back framing a single layer of 1'blanket is tight against the studs for about a foot off the deck..opens up as the oven curves..otherwise I am planning on 3 layers eventually. I have one blanket on and another still waiting to be placed. Where the blanket is tight along the rear studs I am planning on back-filling with loose vermiculite although at peak firing temps the single layer of blanket has only maxed out at about 140 or so
        Peter
        Member WFO-AMB=WW
          Greetings all...I have made some progress on the enclosure but have been way too slow posting!! Here are some pics of the door I put together to get the ball re-rolling as it were. 18 gauge stainless with a 2 inch "shelf" two layers of blanket and pulled together with 1/2 inch cement board. More to follow soon, I need to remember to take pictures
          Peter
          Member WFO-AMB=WW
            Roof is going up.. I have chosen to do things slightly differently, rather than buliding trusses I have built roof panels to which i have attatched the cement board soffits to, then with a flip and some setting I have all the roof framing for one side. Currently only one side up, I am working on attatching the board to the other sid right now. once it is up I will cut the holes for the lights get them wired up and attatch the roofing
            Member WFO-AMB=WW
              Sorry about that, had to cut the last post short..Here are the pictures that go along with my attempt at an explaination. It has worked out well for me. I am not sure if I ended up using more material but it went quick and it was easy working on a pair of saw horses. Second side is ready to go up and as soon as I can find a willing pair of hands I will get it done. Face boards lights etc......
              Peter
              Member WFO-AMB=WW
                Found the willing hands...can't get the weather to cooperate though. It is supposed to be nice tomorrow but between work and having folks over for pizza I am not sure it will make it up. Maybe Sat ...make that Sun working yet another weekend. Ah well, such is life. Pictures once it goes up.
                Peter
                Member WFO-AMB=WW
                  Pics as promised..Not 100 % done but getting closer.
                  Peter
                  Member WFO-AMB=WW
                    That is such a nice enclosure. really well done!
                    Love those downlights aswell, gives it such a nice feel.
                      Thanks for the praise...more photos to follow, I am excited to see how it all turns out too
                      Peter
                      Member WFO-AMB=WW
                        Greetings all,
                        While I was at work this evening my wonderful wife primed all the wood trim for me..drip edge and roofing tomorrow if I can stand the heat. Index of 110 tomorrow
                        Peter
                        Member WFO-AMB=WW
                          Happy 4th all... We have had nothing but hot beautiful weather for the last 4 days or so so I have been able to get the roof mostly on, caulk around the chimney and ridge cap still to do. Had friends over last night for pizza and put the door on when they left. Had potato and cheese fritata for brunch, beef tenderloin with carrots and yukon golds for dinner and finished it with cookies...all from the heat left in the oven .. plus it keeps the house cool !! Here are a few photos, I promise to keep them coming
                          Peter
                          Member WFO-AMB=WW
                            Well, I have two new things to report. 1st, I have finally started on the stones for the exterior, not a lot of progress but I have started!! and I have finally purchased some Caputo 00 should be here by the end of the week....can't wait to play with it and see what the reality of it is..More pictures as things continue to progress
                            Peter
                            Member WFO-AMB=WW
                              Here are some pics of the stone.( OK one pic) I got in a few more rows after dinner but did not get any more pictures..As always, more to follow
                              Member WFO-AMB=WW
