Re: High Heat Mortar Primer
Just to throw another option out there, if one has access to "Glass block mortar" there is a very easy way. Glass block mortar is generally:
If you had a source for pre-mixed glass block mortar, and you wanted:
Then you would mix three parts of the glass block mortar with one part of fireclay:
There was previous discussion regarding the potential for using Type-N pre-mixed mortar; I would caution anyone considering that option to be aware that the ratio of sand in Type-N is 6 parts to one part each portland and lime.
Finally, and someone please correct me if I'm wrong on this, "parts" are very specifically measured by volume not weight. My baker's head wants badly to weigh parts rather than measure their volume which would lead to a major error as portland weighs more than twice what lime does per volume.
arri
Code:
1 part portland 1 part lime 4 part sand
Code:
1 part portland 1 part lime 4 part sand 2 part fireclay
Code:
3 part glass block mortar (pre-mixed) 1 part fireclay
arri
