Re: High Heat Mortar Primer
CaMaHa7
Is it correct that you plan to cast your dome and not use bricks with high heat mortar in between?
I have no experience in casting a pizza oven dome. But I would be very hesitant in doing so without a structural reinforced concrete dome. Dense high heat castablel concrete may good (I do not now), but you should consider reinforcement by using iron reinforcement. Refractory cast needs to cure and sinter at the right temperature to obtain strength and I am not used to think of such a concrete as a structural layer. But I am not an expert here.
I guess the dome diameter and diameter/height ratio comes in as a parameter. Unless this is a very small build I would consult someone who has done this before.
Karl
CaMaHa7
Karl
