Re: High Heat Mortar Primer
Hi Jacktheknife,
Mortar is "sticky" so it holds to bricks. You also want the mortar to be "weaker" than the brick so if there is any cracking it is at the joint and not through the brick. If you want maximum effect of thermal mass then either cast a dome out of castable refractory or cut each brick so the mortar joint is very tight. Also, note that manufacturers sell mortar and castable refractory products but never recommend that they be interchanged.
Cheers,
Hi Jacktheknife,
Cheers,
