High Heat Mortar Primer
This is a sticky topic.
  • #61
    Re: High Heat Mortar Primer
    Hi Jacktheknife,
    Mortar is "sticky" so it holds to bricks. You also want the mortar to be "weaker" than the brick so if there is any cracking it is at the joint and not through the brick. If you want maximum effect of thermal mass then either cast a dome out of castable refractory or cut each brick so the mortar joint is very tight. Also, note that manufacturers sell mortar and castable refractory products but never recommend that they be interchanged.
    Cheers,
    Bob
    Here is the link to my oven number 1 construction photos!
    Here is the link to my oven number 2 construction photos!
    • #62
      There seems to be some confusion here.
      1. Cement is the powdery stuff that sticks the other materials together.
      2. Concrete is the mix of cement with water, fine and course aggregates.
      3. Mortar does not contain course aggregate- fine aggregate only (usually sand)
      4. Castable refractory contains, among other things, both calcium aluminate cement and aggregate which is generally too course for mortar.
      • #63
        Gentlemen,
        I never realized mortar is sticky or that it is not so course as 'concrete'
        {not cement} I understand now why mortar is for bricks and concrete isn't.
        I also never knew there is a refractory mortar as well as a refractory cement.
        Thank y'all a lot!
        J. Winters von Knife
        • #64
          Concrete and mortar are not the same. They do not share the same desired physical properties. Both contain similar ingredients, but that is the only similarity.
          • #65
            Hi from Oz,
            We have several different sands to choose from here IE river, course and fine and also brickies loam, can someone tell me which I should use please?
            • #66
              What is the mixture you are trying to make?
              • #67
                Just the mortar for the dome, 3:1:1:1
                • #68
                  I use fine silica sand
                  • #69
                    Isnt all sand silica?
                    Even the clay in the sand is silica?
                    My Build.
                    Books.
                    • #70
                      Thanks David, I will check it out
                      • #71
                        The reason I use silica sand is because it has sharp grains rather than rounded ones which I think provides better grip when bonded with the other materials. It is also closer to pure silica so has less impurities which can be more inclined to create adverse chemical reactions under high heat conditions. Don't worry about it melting though because pure silica melts at something like 1500C and needs fluxes to bring it's melting point down to about 900C which is still way higher than our range.
                        Clay may contain some silica but among other things has a higher content of alumina.
                        Brickies sand often contains some mud and other impurities, which helps make the mortar workable.This is ideal for normal mortar. Because we use lime and fireclay in the mix these ingredients help to make the mortar workable. So IMO silica sand is the preferred choice. Excuse the longwinded reply.
                        • #72
                          Hi les,
                          Silica sand sold by masonry suppliers is uniform in composition. Other sands have varying amounts of silica and other sand materials. Silica sand is sold in various mesh sizes here in the U.S. from 30 to 200. I've used the 60 and 120 mesh silica sand with good results for Poor Man's mortar. Silica sand is often used for sand blasting applications. If your masonry supplier doesn't carry the mesh size you want then possibly a welding supplier will have it available.
                          Cheers,
                          Bob
                          • #73
                            Thanks for that Bob, sorry I took so long to reply, I work away from home and just got back.
                            I will check out our suppliers.
                            Cheers,
                            Les
                            • #74
                              Thanks David, much appreciated, I'll look around, there is a sand supplier in Bundy and I think he has what I'm looking for,
                              Regards,
                              Les
                              • #75
                                Originally posted by james View Post
                                Hello all,
                                The topic of mortar comes up often, so we are making this a sticky posting that will always be at the top of the "Getting Started" forum for reference.
                                Here is some good background information on the high heat mortar you should use to assemble a Forno Bravo Casa or Premio pre-cast oven, or to build a brick Pompeii Oven.
                                The best solution is to use Refrax, or another pre-mixed true refractory mortar. We stock Refrax and highly recommend it. It is pre-mixed (just add water), sets hard, is easy to work with, fully cured quickly, and is heat resistent to 1700F. Basically, it's made specifically for pizza ovens and fireplaces.
                                If you don't want to worry about shipping Refrax, or want to save some money, you can make a fire clay/Portland cement mortar. Fire clay is a heat resistent clay made up of aluminate and silica. When you mix fire clay with Portland cement, sand and lime, you get a mortar that is more heat resistant than concrete (Portland cement with a sand and gravel aggretate), though less resiliant or thermally conductive than a true aluminate mortar.
                                Here in Sonoma county, you can get fire clay from our big, local masonry supply company, SBI -- who is also a Forno Bravo oven dealer.
                                Here is the recipe for fire clay mortar, where you measure by volume (use a bucket or shovel to measure):
                                1 part portland
                                3 parts sand
                                1 part lime
                                1 part fire clay
                                In between Refrax and fire clay/Portland cement mortar, you can make your own aluminate mortar. It is hard to work with, as calcium aluminate can be challenging. If you get the mix, or water wrong, it won't set correctly. It partially sets very quickly, and you cannot re-hydrate it, so you have to mix it and use it in small batches. Still, if you are trying to save money and want/need the heat resilience, heat conductivity and longevity of a true aluminate mortar, it works.
                                1 part calcium aluminate
                                3 parts sand
                                1 part lime
                                1 part fire clay
                                -James
                                __________________
                                Hi
                                I found this and thought it might help in it lime or portland cement should not be used. Thought it might help
                                High Alumina Cement Construction method:
                                1. When preparing refractory concrete, fix on the aggregate according to using condition. Choose the proper capacity graduation to make maximum density. Be noted to match and adapt with cementing material.
                                2. According to certain proportion, add water and mix by man or machine into mortar and then begin casting construction. Use up the ready mortar within 40 min. Calcium Aluminate Cement?s hydration heat concentrate on early stage. Casting thickness should not exceed 3 cm each time. Water curing immediately when concrete goes hardening and the curing time should not less than 3 days.
                                3. When prepare expanding cement, Calcium Aluminate clinker?s dosage is 73-76%, CaSO4?2H2O dosage is 24-27%. When prepare self-stressing cement, the mixing ratio of CaSO4?2H2O should be increased.
                                High Alumina Cement Notice:
                                1. In order to avoid uncontrollable setting time, do not mix with Portland cement, lime etc of which separate out calcium hydroxide cementing material. Before use, clean all the mixing machinery. [/COLOR]2. Steam curing to accelerate concrete?s hardening. The curing temperature should not higher than 50?.
                                3. Refractory concrete?s late strength decline big, design should according to the lowest stable strength. CA-50 bonded concrete?s lowest stable strength should be determined by the lowest strength of 7-14 days of demoulding sample curing in 20??1? water.
