Re: Oven on wheels
Gudday Mick
About those insulation batts......you can use them IF you have a fair insulation in place already to take up the big heat against the brick. My own oven has 2" of ceramic insulation and 4" of fiberglass batts and works real well. I took a section of the dome off and peeled back the insulation to check the temps during a good flash up. No problems. If you type in "Hi,new Aussie" in the search you'll find I put the readings I got in that post. I've since read of a couple ovens (not in forno resourses) use a layer of clay/straw then fiberglass batts.
Recon you might consider pearlite/cement over your dome because loose fill will have a tendancy to settle over time then stuff the rest of the enclosure with Batts.
Regards Dave
Gudday Mick
Regards Dave
