Re: Oven on wheels
The two arch bricks are 400 apart, a bit less than 4 bricks wide, and I was going to cut the two outer ones to slide in. Just discovered the brick won't fit in my saw for the long cut, so I just cut two bricks off and laid em crossways in clay. They come just to the front of the arch bricks. Its all tarped up now, so I can't quickly take a photo, but they will be captured by two ordinary bricks mortared with the real stuff later. Its testing me!!
It should all work out eventually, I suppose if it was easy, anyone could do it.
That clay is surprisingly good at holding stuff where you put it though.
The vermicrete came up as rough as rough, but a 1/4 inch skim of clay sorted it out. Any biggish holes just filled with clay.
I'm not even that concerned about it getting wet once its done. I think it'd pretty much have to fill the floor up first, which is quite a bit of water.
, thank goodness for light beer, etc. Turned a bitumen road 220 km round trip into at least 300 km. I was trying to show him that there are way more interesting things in the world than video games and lap-tops.
