Nick J C did you say you have fitted a breather valve (or equivalent) as we are talking about on some of the other threads?
Record of my 32" Homebrew cast oven, on a brick base - West Midlands, UK
Oven costings for those in UK interested in how big a hole you will burn in your pocket - still have enough materials for render, and still have a reasonable amount of materials left (almost a full bulk bag of sharp sand of which I used about a third for the sand castle, and got it back!). Obviously the brick base is dependent on your chosen design, but you are likely to need similar.
Oven:- Stainless flue 6" 1m + 0.5m = £58 (ebay)
- Fireclay 25kg bag £30 (inc delivery) valentines clays
- Firebricks x 30 £75 Vitcas
- ceramic blanket 7.3m x 1" £65 Vitcas
- ceramic board 1x1x1.2m £60 Vitcas
- delivery from Vitcas (pallet) £40
- Cement 25kg x 2 £10 Selco
- hydrated lime 25kg x 1 £12 Selco
- Sharp sand (from bulk bag costed in base)
- Stainless needles 3kg £50 Rockbond (inc delivery)
- Polypropylene fibres 900g £11 ebay
- vermiculite 100l £24 ebay
- perlite 100l £24 ebay
- blue quartz glass (arch) £4 ebay
Brick Base (concrete foundation, brick wall and reinforced slab with thermolyte topping):- Cement 25kg x 10 £40 Selco
- OSB board for formwork £20 Selco
- builders sand (mortar) 6 bags £15 Selco
- Ballast (for concrete) 1xbulk bag £50 Selco
- Sharp sand (for sandcastle/dome casting) £50 Selco - used less than 1/2 and got most back after sand castle
- blue bricks £100
- thermolyte blocks x 10 £12 Selco
- rebar mesh 3.6x2m - £20 Selco
Total Cost for both Dome and Base: £790 or $985 USDLast edited by Nick J C; 07-03-2020, 08:37 AM.
- 2 likes
Great Build Nick, and great to see you've got it fired up. I'm currently playing the waiting game myself. I like your temporary roof, may have to build something like that for mine. I have borrowed a friends gazebo, but he might not be impressed if I cut a chimney hole in it.
Congrats on a nicely executed cast oven. You did your homework and research up front and it shows in the final build. Enjoy the oven, as you can see, it can be used for much more than pizza. If you want to see a broad variety of dishes from a WFO, look at Karangi Dude's thread "What's Karangi Dude Cooking"Last edited by UtahBeehiver; 07-04-2020, 11:58 AM.Russell
Graduated to pizza, started small with a micro pizza...... Dough proved nicely on warm gallery, then fired up. Steep learning curve on getting them into oven....plenty of flour on paddle. Tip of using squirty bottle to add pureed tomato sauce sparingly worked well..... Compliments from all who tasted
Good work Nick J C .
i picked up a tomato sauce recipe a while back that is awesome - can of tomatoes blended with salt, olive oil, oregano, fresh basil and garlic granules/powder. Has taken our pizzas to another level!
