Okey, instead of starting new threads with different questions I'll try to document my journey building an neapolitan oven with homebrew cast. I have never built anything in my entire life and I have already encountered more challenges than I initially thought. It's exciting!
Location, foundation and stand:
I initially started digging for my foundation at a place where the ground was very, very wet. I had to change location and it was better - but there were lots of roots from a birch and stones so it was very challenging. I dug for a total of probably 15 hours. My foundation - which I did for a couple of weeks ago - is 1200 mm x 1400 mm. I made the pit almost 2200 x 2400 mm and fixed drainaged pipes and isolated with cellplast/cellular plastic. The foundation is 100 mm thick aerated concrete with reinforcement. The pit is now filled with gravel. I had to use drainage and cellular plastic because of the ground frost (not sure of the translation here...) and I don't want the foundation to lift when the cold weather hits.
The stand is made with 30 pieces of 150x190x590 mm blocks.
This weekends project is to make the concrete table. I'll use fine concrete, reinforcement and the plan is to make it 1200 mm x 1400 mm (or slightly bigger) and 70 mm thich. The reinforcement is only 5 mm thick so I will also use a couple of rebar (unknown size at the moment, but a bit thicker then the mesh).
Does this sound like an ok plan? Will the concrete table, foundation and stand be strong enough for the oven?
Oven plans:
800 mm ID
50 mm cal sil board directly on the concrete table
30-50 mm mix of sand, ash and salt to lay the floor on (napotalean style)
32 mm firebricks (biscotto bricks from Italy)
260-290 mm dome height inside (I've read that n
eapolitan ovens have a lower dome height)
50 mm homebrew casted on sand dome with SS needles and PP fibre
25 mm or maybe 50 mm ceramic blanket (the blanket is 25 mm but I'll try to make two layers)
50 mm perlite/portland
Chimney: 150 mm diameter. 1000 mm height.
I'll attach a couple of picture from my work so far.
Input is welcome!
Oven plans:
800 mm ID
Input is welcome!
. Waiting for the experienced posters to chime in.
). 50 mm of CalSil under your cooking floor is the minimum (and common builder's choice) for insulation but adding any additional insulation under the board is a good thing (again imho
I of course do understand the meaning, but I have just ordered 200 litres which is enough for the on oven insulation - but not for both. My budget is already broken so my better half won't be super happy if I keep buying stuff for the oven!
