I’ve not used the silicone treated stuff because it’s not available to me, but it is possible that it reduces the bond with the cement on the surface of the grains, having a greater tendency to wash off the grains. The stuff designed for agriculture and nurseries is not coated and designed to hold moisture. Someone else who’s had experience with both types may chime in.
There is always some reduction in volume (around 20%) when mixed with cement and water. Do not use a mixer as it abraded the grains and results in even further volume reduction. It is better to mix it gently in a barrow with a spade.
) than it is to "miss a day or three" in the curing sequence.
