Sidetrack , I saw your comment on creating a sectional dome in Kris S's build threat. Didn't want to hijack that thread. The idea is intriguing.
I am planning for my own cast build. Base is complete. I have a few weeks wehre I won't be able to make much progress other than planning the final details.
Here are some thoughts:
Any thoughts are welcome.
- make three sections, and a top part, would have to make sure that the top (plug) is tapered so that it does not fall through
- Maybe use thin cardboard to keep the seams thin
- Maybe fold the cardboard into a wedge shape I don't think I could do the nice bullnose that you have drawn, but maybe a triangular shape
- Or maybe even simpler, make a step in the homebrew 1" wide (see attached sketch)
- would also have to place something between the firebrick and the dome (cardboard?)
- Let the Homebrew cure for 48 hrs, remove the sand, fix any imperfections on the inside, let wet cure for at least another 5 days
- Once everything is cured, I would have to take the dome apart so that it can be put together again using high temp mortar.
- Or simply burn out the thin cardboard and let it settle?
