Originally posted by kebwi
View Post
Not being sure how it would work out, I advised two interested homebuilders here way back in around 2010. As it turned out those two ovens are still performing well so I've continued advising others here of a simple, fast and cheap way to build a home oven.
I don't have the time or inclination to write a book on the subject, but happy to field any questions. I suggest you read as many of the cast builds that you can find here.
Those are the correct fibres to use, you don't need much, but they need a lot of mixing to disperse sufficiently. As well as burning out they also do a good job of holding the mix together and eliminating slump cracks, but don't add additional strength.
