Re: Bend, Oregon USA 29" interior Floor
Dino
I started with my First coat after the metal mesh on Tuesday night and I waited until today to build the Stone Face this morning with special high heat epoxy that I bought at Home depot.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
http://www.homedepot.com/Paint/h_d1/...atalogId=10053
I drilled holes in the back of the rock and then glued 1/4 by 1 1/2 bolt to the rock then I drilled a 3/8 hole in the Brick then I glue the stone to the brick.......Then at 5pm I started with the last coat of the oven before the Drivit.
I used some hidden tricks I never told anyone until NOW
The skim coat has Stainless Steel Needles
Refractory Reinforcing 1" Stainless Steel Needles 10# - eBay (item 130337734449 end time Apr-14-10 07:04:54 PDT)
The last coat has Fiber mesh in it
Enduro Macro Micro Synthetic Concrete Fi - Propex Concrete Systems
This is the ticket to help it from not cracking and structural sound
OK Chris...when did that outer arch happen! It's absolutely beautiful! That stone is amazing. Great choice in stone material.
-DinoLeave a comment:
Well we put the skim coat over the metal mesh....then we coated it one more time
With the last coat we put fiber mesh in the concrete.
I set the front rock also I used a special high temp epoxy and drill holes in the brick so it will be structurelly strong and it will not fall off3 PhotosLeave a comment:
Well here is the last picture
And here is what I did
I have 3" of ceramic blankets then I have alum foil wrapped
Then I have Alum mesh
I am going to skim coat it in Mortar tomorrow
What you think?
Chris1 PhotoLeave a comment:
More pictures5 PhotosLeave a comment:
Well I started on the Insulation today and I am going to coat it tomorrow
Here are some Pictures of what I did today5 PhotosLeave a comment:
Chris, don't worry about the hairline cracks. You'll have lots of them; they are normal. The oven has to expand and contract a lot. I think the more small ones you have the better. Even the larger crack (when your oven is at it's hottest 7-800 deg and then one of those hairlines gets almost credit card thickness, it's still no big deal. It's not big enough to loose heat or smoke through the insulation blanket you'll wrap it in. Now that's worst case if it happens at all.
Looks fine-DinoLeave a comment:
Crap - sorry about that
Nuclear is when you have flames jumping out of both orifice's.
It's fun to watch...
Les...Leave a comment:
What is nuke to you ?????? because I am only going to run it about this hot or just a little hotter
HEY you let the cat out of the bag :P
Thanks alot I was hope not to let it out of the bag until about 50 more posts/
Chris
Oh well maybe nobody will see it
Chris - Before you wrap it up - bring it up to nuclear to see what happens. I think your approach is solid, so I don't expect any thing bad. Since this thing is destined for the road, I would start looking at cushioning the transport.
Another good day Firing and Curing the oven
These are approx #
Roof is 850-975
Floor is 609-750
Walls at solider row 595-620
Outside 205-295
Under the oven 179
What do you all think of the #'s?
The Bricks in the last picture is just starting to glow. and you can just barely see them
I do have about a dozen or so Hairline cracks
I think these are from expanding brick and mortar???
I think I will start on 2-3" Blankets and alum foil and chicken wire and mortar and dryit after that3 PhotosLeave a comment:
Well today was a good day
DAY 4
There are zero cracks that i can see inside the oven
there are some hair line cracks on the skim coat that i put on after the 16 gauge chicken fence, this skim coat was about 3/4- 1 inch thick in some places.
I want to see what will happen tomorrow before i put the ceramic blankets on.
I am hoping that this will insure me of huge cracks later down the road
Fired and cured oven at
ceiling 650
floor 486
Walls 539
outside 174
I think tomorrow i will try to fire it up to about 800-1000 on ceiling.
The heat tranfering from flame to bricks i feel is going well.
ChrisLeave a comment:
I cut the opening 6 x 9 and tappered it to 4 x 6 then i used the 6in circle chimneyLooks like a good product, but they all look round (cylindrical) to me. Did I misread something?Leave a comment:
I am using supervent as the flueLeave a comment:
