Starting to build...using the Heat Stop 50.
42" Oven
Tags: None
Re: 42" Oven
Looking nice - that part is the most fun (although it all is pretty fun). Enjoy!Pizza Oven Picture Gallery
http://picasaweb.google.com/toddfas/PizzaOvenProjectComment
Re: 42" Oven
starting on the arch openings and noticed that there are all sorts of different sizes. Since I'm doing a 42" oven (Tuscan style - higher dome), should I start the arch after my fourth brick on the sides, going up to the height of 12.5"? I noticed lots of people doing it after the third brick, but that starts at 7.5" and looks like it arches up another 2-3", so I'm assuming they're doing the lower domed ovens? Thanks for any help...Last edited by doobie dee; 06-04-2010, 05:44 PM.Comment
Re: 42" Oven
I started at the third brick with an opening of 12.5 inches. It gives me plenty of room to cook and gives the arch sufficient strength. My oven it 42 inches and the dome height is 21 (a little less due to the flatness of the plug). Hope this helps.
Les...Check out my pictures here:
If at first you don't succeed... Skydiving isn't for you.Comment
Re: 42" Oven
Fourth course down...also started the base for the arches. Perfect weather for building.5 PhotosComment
Re: 42" Oven
Looking great so far.
Good to see you have taken the plunge and rebated your Openning/Inner arch.
It is fairly complex but worth the time spent
CheersJohn
__________________
My Oven Thread:
http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.Comment
Re: 42" Oven
Hey John,
Thanks. Have a question. What do rebating my opening/inner arch refer to?Comment
Re: 42" Oven
I'm thinking about using splits on my inner arch. Has anyone else tried using splits? I was thinking it could help with smaller joints.Last edited by doobie dee; 06-07-2010, 08:04 AM.Comment
Re: 42" Oven
Hi Guys
Should have used the correct terminology, I meant reveal.
I use to be a cabinet maker hence the use of Rebating
John
__________________
My Oven Thread:
Re: 42" Oven
Just finished my first arch...pain in the boodie building the form but it worked out pretty well...I'll take the grinder to it when it hardens and smooth out the rough edges. I think I'm glad I used the splits.
I was starting on the next couple of courses when it started hailing on me...it's mid-June.2 PhotosComment
