Re: Sydney Construction Has Started!!
I haven't logged on in a while since I got cooking and am a little surprised about the lateral support issue, How long till I should expect to have problems? Its been a few months and no cracks in the flue arch or chimney have occured should I be concerned?
I have noticed one thing though, I made a sandwich construction door for the oven with 1500 degree fire blanket in between the 3 mm plate. However if I build a big fire for a few hours and then sweep out the coals and embers I am finding the thermometer is only reaching loww 100 degree celcius??? The walls are 200% or so but the internal temp will not raise over 120. It retains temp well with the temp the next morning only dropping 30*. However I would like to do a full lamb and have already made the tray but I need 160 min for 4 hrs to do a whole beast. I dont want to undercook it, 180 for 3 hrs would be better.
Is there a trick to firing the oven and getting the heat into the refractory bricks??
