28" Pompeii
  • ggoose
    • Sep 2010
    • 202
    #16
    Re: 28" Pompeii
    OK John and dmun, thanks....homebrew it is.
    • ggoose
      • Sep 2010
      • 202
      #17
      Re: 28" Pompeii
      I have been perusing threads on homebrew, but can find nothing on some of the specifics...
      Lime: quicklime or hydrated? If hydrated, Type N or Type S?
      Sand: I have seen reference to 60# and 120#, and silica for the sharp edges. Is this a good sieve range?
      Fireclay: This seems like a gereric term; what should the minimum aluminum oxide content be (or does it matter)?
      Sorry for tha barrage of questions, but at this point I get the feeling that I don't even know what I don't know
      Thanks again for any replies,
      gene
      • GianniFocaccia
        • Jun 2009
        • 1645
        #18
        Re: 28" Pompeii
        Gene,
        I'm not too knowledgeable on lime although I went with the Type S hydrated lime. Here is a brief analysis of the different types of lime. It appears the difference in N and S is in it's compressive strength.
        My silica sand is #120, mixes up in the homebrew recipe like butter and cures out really hard. Two notes on my application of homebrew: the outside joints that are closer to 1/2" (first eight courses) show no cracks at all. The last few courses, though, are just under 3/4" and a few really tiny hairline cracks (maybe half an inch long) have appeared. I would consider mixing in some #60 silica sand if your outside joints are going to be larger than 1/2". This is because portland shrinks as it dries and larger pieces of aggregate minimize shrinking.
        I have been extremely lucky with drizzly (is that a word?) weather during my build and I have not had to drape a wet curing towel over set bricks except a couple of times.
        Fireclay - It believe it is optimal to use the clay dust from your brick cutting to 'match' the properties of your firebricks. I have intermittently added my own harvested brick dust to the mix but more regularly used 'mortar clay' I bought in a 50# bag (H.C. Muddox) because of convenience. Over the course of my build I have wondered (but that's all) how effective it would be to mix very small firebrick chips as aggregate into the mortar that goes into the outside of the joints.
        John
        • AtTheLake
          • May 2011
          • 34
          #19
          Re: 28" Pompeii
          I also opted against the Sairset and went the Homebrew route. (Changed my mind in the store after I already ordered it). So far the Homebrew has been great. Dries rock hard and impossible to get bricks apart after a week of curing.
          I bought "Miracle Hydrated Lime" from the local masonary supply house. Lowes also carries it. With a name like that it has to be good. For sand I am using the fine silca sand from Home Depot. For fireclay I bought #20 and #30 from the refractory supply house. I have mostly used the #20.
          One nice thing about purchased fireclay verses the stuff from your saw is that it is perfectly dry so I can premix 50lbs of the dry mix in a large tote and then just mix up small batches with water as I need it. This also keeps your mix very consistant.
          Dino the refractory store sells bags of the firebrick chips for exactly that (large gaps). They called it "Grog"
          My build thread:
          http://www.fornobravo.com/forum/f8/m...-mn-15832.html
          My oven build pictures:
          http://markandcherylscabin.shutterfly.com/pictures/178
          • ggoose
            • Sep 2010
            • 202
            #20
            Re: 28" Pompeii
            Thanks for the input guys.
            The homebrew sounds like a good alternative. I priced the FB mortar and it is $50 plus about $40 shipping to my area. I do like the fact that it contains no portland cement, and even with shipping is considerably cheaper than Heatstop (~$120 w/tax around here).
            I just received my FB insulation today, so as soon as the rain stops in the next few days I can set the hearth insulation and begin the firebrick work. I have been working on the dome-to-arch transition in my garage and I think I may rent a 14" brick saw to cut the tapers for the top of the arch. My 10" saw (and my proficiency level) aren't cutting it, so to speak.
            • GianniFocaccia
              • Jun 2009
              • 1645
              #21
              Re: 28" Pompeii
              Gene,
              Sounds like you are on your way and staying ahead of the weather!
              I have never rented a saw, but be aware that rental yards make their money on blade 'wear', which they measure, not you. In every case I have heard of, the charges for the amount of wear you incur are excessive and can almost pay for a brand new blade.
              John
              • ggoose
                • Sep 2010
                • 202
                #22
                Re: 28" Pompeii
                I have pulled the forms from the hearth and am fiddling around with the dome-to-arch transition, cutting the bricks ahead of time. I am hesitant to make too many cuts on the dry run before actually setting the bricks with mortar, as the gaps will most likely increase with the addition of mortar and render the dry run cuts inaccurate.
                • GianniFocaccia
                  • Jun 2009
                  • 1645
                  #23
                  Re: 28" Pompeii
                  Gene,
                  Nice-looking start to your inner arch. Love the angled bricks! The toughest part will be maintaining the inside arc to the arch while keeping the outside (flat) brick faces plumb and flush. This is where patience is a virtue. I recommend cutting your center arch brick first (match this brick's inside face to your dome template) and then scribe a circular line (indispensible tool) down the top of this brick to your outer-most arch brick. This will give you the inside arc you need.
                  John
                  • ggoose
                    • Sep 2010
                    • 202
                    #24
                    Re: 28" Pompeii
                    Thanks John; sounds good. I'll likely begin the mortaring tomorrow. I have to get some sort of cover to protect the build from the elements and tree pitch until I get a roof over it.
                    • ggoose
                      • Sep 2010
                      • 202
                      #25
                      Re: 28" Pompeii
                      Today I set the hearth insulation and cut and set the floor bricks. The floor was a little trickier than I imagined, as the fireclay mortar sets up pretty quickly. If you have to adjust the layout once you begin you basically have to pull the affected bricks and re-butter them, as the insulation wicks the moisture away from the mortar rather quickly. I guess it took me about an hour, and I ended up with a few edge joints a little wider than I would have liked. A little sand should take care of that.
                      Tomorrow I will try to set the first course of oven dome bricks. Question for those who've been there/done that: do you fireclay-mortar the bricks to the hearth insulation and refractory-mortar them to each other (the sides I mean)? Or do you just set the dome bricks right on the insulation and call it good? My insulation seemed a bit uneven from the manufacturing process, so I thought a bed of fireclay might even things out, but that would mean two different mortars going at the same time
                      By the way, my 28" pompeii has grown to a 32" pompeii...must be all of the rain
                      • asudavew
                        • Jul 2007
                        • 1880
                        #26
                        Re: 28" Pompeii
                        You can use sand to level the insulation, if it worries you. Just throw a small layer on top and level it out.
                        No need to mortar down your soldier course, but you do want to mortar them together.
                        I hope this helps.
                        My thread:
                        My costs:
                        My pics:
                        • asudavew
                          • Jul 2007
                          • 1880
                          #27
                          Re: 28" Pompeii
                          And! Good looking build so far!
                          Good luck to you!
                          My thread:
                          My costs:
                          My pics:
                          • ggoose
                            • Sep 2010
                            • 202
                            #28
                            Re: 28" Pompeii
                            Thanks asudavew,
                            I wound up fire-clay mortaring the insulation down and just setting the soldiers on the insulation - no mortar.
                            On another note, I am trying a bag of the FB50 refractory. Have you used this product? Is doesn't seem to be very "sticky"...how wet should it be mixed? I am concerned with it bonding strength as I have mixed it (though perhaps improperly), because as I set it between two bricks, it seems to be already too dry to bond, and that is with the bricks being fully hydrated. Perhaps refractory mortar should be mixed much wetter than normal thinset? I am thinking I might need to pull up my soldiers and try some homebrew, as others have had good success with it.
                            Some advice please...
                            • GianniFocaccia
                              • Jun 2009
                              • 1645
                              #29
                              Re: 28" Pompeii
                              Gene,
                              I had the same non-sticky problems mortaring my soldiers - so much so I abandoned that design and went with all-horizontal courses. I found that the brick weight of each successive course made for a better bond, but you don't have to do this. With the homebrew I merely made the mortar wetter (but not soupy) and my bricks have bonded together like super-glue. Sure, it takes a week or two for the bond to fully set, but I bet your FB mortar works the same. Can you do a test?
                              • ggoose
                                • Sep 2010
                                • 202
                                #30
                                Re: 28" Pompeii
                                Hi John,
                                I too placed my soldiers flat (so I guess they are not really soldiers?) and mortared them to each other. This was about a week ago and the bond is very strong. I mortared two scrap bricks together as a test piece to play around with, and, even with a reasonably forceful attempt, cannot break the bond (in tension, not torsion). So I am happy with the result; it is the workability that I dislike - similar to wet sand; no flow or "squishyness" to help uniformly distribute the mortar when the bricks are presses together, as one finds with regular mortar. I was thinking of adding some fireclay to the mix to aid the workability, but I have no idea how that will affect the behavioral characteristics of the cured mortar. Any thoughts?
