May be starting my 42" Pompeii in NYC this week...
Re: May be starting my 42" Pompeii in NYC this week...
Question, once the slab is on, can I use a 4" layer of vermiculite with Portland as my base for the firebrick floor or do I need to get the FB board on top of the vermiculite first?
That is an either or. Vermiculite/ Portland cement OR FB board. You could do both but that would be over kill. Then you set your floor on top of whichever one you choose
Nice start NYC, I can tell already by your work you'll be glad you built one yourself. It's going to be nice. If you go with vermicrete as I did for your insulation, keep in mind a 2x4 form will only give you a shade over 3 inches thick. I was able to slide my form up after the initial few inches and put another inch and a half. I used a 5:1 ratio of vermiculite to portland which worked out well.
Leigh
Does the V need to Spanish the entire slab or just an area large enough to house the oven and landing since it is simply and inslating layer for the floor?
OK, day 2 I finished the block stand and filled some of the corners. It started raining so I couldn't fill more. Next up is the forms and slab. I may have to get one of my guys to help so this moves faster. I spent two whole days and only got the slab and stand up.
OK, today I finished pouring the concrete in the blocks and got the rebar in them. I then made the form for the slab and tomorrow will pour the 4" supporting slab if the rain stops.
I also stucco'd the inside of the blocks with a water tight fiber reinforced resurfacer.
