Re: Texman Build
I was sitting here thinking " i could put that on a spreadsheet"
JCG31 did the this chart which is great, but once you have a deviation from normal, you are off. I like calcing each course based on the one below. I did first two courses vertical and then began the dome curve. So i would have to calc each course.
I am glad you get it, it started to sound like gobbly-gook as i was writing it. It is one of those "as simple as it can be, but no simpler things." This would have been great starting on the first course.
What makes me feel stupid, is i did all this for the arch and even drew it out and made a pattern and proved it worked and then just forgot it all and started cutting bricks like i knew what i was doing for the dome. And then did that same thing for 10 courses.
O well, i blame mine on the grief of starting over. Will anyone believe me?
